Name These Pieces???
Old Apr 17, 2006 | 09:04 PM
Yellowsierra's Avatar
Is it part of one of the rocker arms...where the needle bearings go?
I think its a inner valve spring if your running the dual patriots....
Old Apr 17, 2006 | 09:06 PM
Yelo's Avatar
Maybe the outside of a bearing race from one of the rocker arms ??
Old Apr 17, 2006 | 09:08 PM
v8
17,16,15,14,13,12,11 Drvr
here is the oil pump assembley
http://i17.photobucket.com/albums/b9...r/100_1406.jpg
Old Apr 17, 2006 | 09:09 PM
v8
still way to small to be the inner spring.
Old Apr 17, 2006 | 09:10 PM
v8
you might be onto something, I think i heard somthing break when i put the one in the back on the driver side. Well I will have to look at it on friday.
Old Apr 17, 2006 | 09:43 PM
TXsilverado's Avatar
is there any type of washers where the bolt goes into the pan? like some kind of soft metal gasket attached to either the bolt, or the pan...for some reason i want to say theres something there but im probably wrong. if it is what im guesssing, there would be nothing wrong, but i would have to go pull my plug and check for anything like that and i dont have money for more mobile1
Old Apr 17, 2006 | 10:06 PM
v8
nope no washer on the oil pan bolt.
Old Apr 17, 2006 | 10:53 PM
ThunderZ28's Avatar
12 Second Club
looks like the nut between the steering wheel, and the gas pedle finally broke
Old Apr 17, 2006 | 11:26 PM
negativeswitches's Avatar
i'm voting this is what came to my mind first
Old Apr 17, 2006 | 11:31 PM
Flyer's Avatar
That's the only semi logical thing I can think of, a rocker arm coming apart. If that was the case though, you should see some needle bearings in there soemewhere.
