N/A 500hp-600hp 6500rpm redline LQ9 (lq4 block with flat top pistons).
I'm about to build a lq4 with flat top pistons(basically an LQ9) and wanted to post on here and ask around to see what can I do to make 500-600hp N/A with a 6500 rpm redline. Stroker kit? Cam lift, dur, lsa? Bore over?
strutaeng (11-22-2023)
Yea, a 408 is perfect for what you want. I DD mine for work and play with it also. Mine has K1 crank and rods with diamond pistons specially designed for a stroker. Go on summits web site and start looking and asking questions.
Lq4
Hey guys have couple questions I have a 2006 z71 4 door with a lq4 6.0 5364 heads ls3 and new body intake with xlink 1 7/8 headers 230/238 tsp cam 620 615 running a 4c stall with 4.56 gears and a under pully from summit heads are .30 cut built tranny 4L65 I wanna go with Holley hi ram is the new body intake better than the hi ram being my truck so heavy or would it work better want a hi ram or the carbon fiber ptr but don’t wanna spend the money if ain’t gonna help at all
