LQ4 or LQ9
Old Aug 14, 2003 | 11:52 AM
Smoky02's Avatar
Default LQ4 or LQ9
I am planning on building a stroked 408ci motor, and I was just wondering which block would be better to start with?? Or does it even matter??
Old Aug 14, 2003 | 11:56 AM
IslandTahoe's Avatar
Default Re: LQ4 or LQ9
If were going to rebuild the motor w/ a new rotating assembly(pistons, rods & crank), I would start w/ a LQ4. The LQ9 is desireable for the stock pistons which increases compression over the LQ4.
Old Aug 14, 2003 | 11:57 AM
silent1's Avatar
If you're doing a stroker setup, all you'll be re-using is the block and heads, which are the same for the LQ4 and LQ9.
Old Aug 14, 2003 | 12:01 PM
Smoky02's Avatar
I thought the LQ9 had aluminum heads and the LQ4 did not...
Old Aug 14, 2003 | 12:02 PM
silent1's Avatar
Only pre-2001 heads were not aluminum.
Deckhand's Avatar
i think the lq9 is high-output, it has like 45 more ponies
Old Aug 14, 2003 | 12:10 PM
silent1's Avatar
The "high output" comes from higher compression via flat top pistons, tuning, and I believe a different cam. Either way, none of these will be re-used in a stroker application.
Old Aug 14, 2003 | 12:13 PM
Smoky02's Avatar
so it really doesn't matter which motor I use as long as I get one made after 2001, alright guys thanx
gmcyukon
Oct 5, 2015 06:20 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
The_W
Oct 1, 2015 02:35 PM
