lq4 or lq9 or other 6.0 ?
Old Jan 27, 2006 | 09:08 PM
nightrunner's Avatar
Mr. Obvious
Default lq4 or lq9 or other 6.0 ?
what is the best 6.0 to build
and how do you get a 418 or more
already heard about the 408 but want to go bigger
Old Jan 27, 2006 | 10:00 PM
1SlowHoe's Avatar
Destroyer of Transmissions
The only differences between the LQ4 & LQ9 are the dished(LQ4) v. flat top(LQ9) pistons and the rods on the LQ9 are thicker/stronger. If you're gonna bore it out anyway then it doesn't matter. You will pick the rotating assembly based on the bore and compression you want. The block is the same on both motors. All your accessories will swap right over. You should just be looking for a bare block so you don't waste $$ on parts you wont use.
Old Jan 27, 2006 | 10:34 PM
Rhino79's Avatar
9 Second Club
408 is 4.030" bore and 4.00" stroke and the 418 is 4.030" bore and 4.10" stroke.
Knightcrawler
Jul 20, 2016 03:29 PM
ls1stang
Oct 15, 2015 11:41 AM
lxcoupe
Sep 29, 2015 09:20 PM
FormulaZR
Sep 14, 2015 05:23 PM
zraffz
Sep 8, 2015 07:40 PM
