mysterious coolant leak.....can't find where...
Old Nov 3, 2009 | 06:41 PM
Grumpy5.3's Avatar
I have replaced 1 or 2 heads on 3 trucks in th past month. Pull your oil cap and see if water or moisture is in there. I would pull the valve covers off, you are going to change oil again after you install new heads. This may or may not be your problem, check everything else first.
Old Nov 3, 2009 | 07:00 PM
fastnblu's Avatar
No, mine were the W/P gaskets. I knew bout the oil cap trick. It appears milky if there's a prob.
I was just lookin for how many instances u had heard of.
Old Nov 9, 2009 | 10:54 AM
icedenali's Avatar
Wow. it's crazy, i have check everything. has not found leak yet.?.. it only leak when i push truck hard. if i dont drive it hard it doesn't seem to leak.
i can't find trace of where it leak. seriously it's not even funny now.
i dont think it's head bolt or head gasket.
Old Nov 9, 2009 | 02:51 PM
Dewey's Avatar
on my obs chevy, my water pump went out and there is a small valve on the bottom that was broken and leaking coolant. check the underside of the water pump and see if that's where it is coming from.
Old Nov 9, 2009 | 07:37 PM
slow.8's Avatar
my mysterious leak ended up being water leaking past the head bolts, or so i was told. had moisture under cap. i was losing a lot of coolant.its parked now,i either have no oil pressure, or my gauge took a ****, im thinking the former.
Pimpinpete
43
Dec 22, 2017 08:13 AM
6.0l RST
Nov 23, 2015 11:30 AM
lxcoupe
Sep 21, 2015 11:53 AM
kmcn47
Sep 17, 2015 01:12 AM
