My e fan install
Old Jan 10, 2010 | 09:01 PM
  #31
crisp's Avatar
Originally Posted by siktruk
either get the 05 34" radiator with the fans or use your stock radiator with some Ls1 fans
Thanks! I'll look into some Ls1 fans. Also been reading over the BlackBear site! I think I may do their tune... and the e-fan harness, too.
-crisp
Old Jan 10, 2010 | 09:02 PM
  #32
SLOXCAB's Avatar
Do it!!!!!!!!!!!
Old Jan 10, 2010 | 09:03 PM
  #33
Black'Rado's Avatar
Go with a blackbear tune and harness!! excelent product and tune....i got a live street tune and damn what a difference....im very happy with my BBP services. i installed my ls1 fans today with his harness
Old Jan 10, 2010 | 09:12 PM
  #34
crisp's Avatar
Thanks for the feedback! For a novice with these trucks, it is confidence building to hear strong support for sponsor/vendors cited within the forum. I'm particularly interested in the upward flexibility with re-tune capability. Being a long-time carb-to-EFI motorcycle tuner... and piggyback tuning through wide and narrow band (for closed loop) on my supra for many years... I'm also interested in this EFI-Live that I am hearing about. I like to fiddle myself... heh heh heh... once I understand these motor/management systems a little... perhaps I'll be able to dive into some more sophisticated real-time feedback tuning?
...we shall have to see...
PS: I'm also inclined to look into long tube headers from what I've read so far... what about the rest of the exhaust back?
-crisp
Old Jan 10, 2010 | 09:26 PM
  #35
Black'Rado's Avatar
im the same way about fiddling with stuff....im going to purchase efi live after i get some extra cash....justin at blackbear is a dealer and teaches a class on it so im sure he can help u get started with it, as far as exhaust goes, look at the lpp longtubes and off road y pipe then a good muffler will be suffecient enough.
Old Jan 11, 2010 | 11:12 PM
  #36
SilverDog's Avatar
Very clean install. It's amazing how much additional room it creates.
Originally Posted by black00chev
Has anyone run the fans through the PCM but added a switch to command them whenever as well, say for track use?
Yes, not hard to do. You basically remotely ground the PCM pins. I can provide a schematic if needed.
Old Jan 13, 2010 | 06:00 PM
  #37
CashDudeHomie's Avatar
I love the fans too. I have a 2000, so I can't take advantage of the AC pressure option, but I still used the two pin setup to activate the fans when the two temp thresholds are met.
I bought a sponsor harness, but it didn't come with fuse holders so I added my own. (I wouldn't run those bad boys without fuses. They draw lots of current.)
I just ziptied my relays to the battery cable to make it easier to remove the fusebox cover.
Old Jan 28, 2013 | 04:27 PM
  #38
iregret's Avatar
Charlie Murphy!
I'm in the middle of putting LS1 fans in my 2000 Silverado. I'll have to check but I think I have the one pin AC harness. It taps the AC line (green) going up past the intake manifold.
So are you saying that this will not work on my truck?
It's a Nelson harness. It had me insert into pin 42. I bought this years ago and am just now installing it. Was the 2 pin harness what I actually needed?
Old Jan 28, 2013 | 05:10 PM
  #39
iregret's Avatar
Charlie Murphy!
Well according to this I'm doing it right.
http://www.ls1fans.com/site/mobile?u...tions.php#2684
An excellent write up.
http://gmfullsize.com/forum/showthread.php?t=229730
If my LS1 fans aren't enough, I'm going to go the factory route like in that link.
Old Jan 28, 2013 | 09:03 PM
  #40
Either one will work. HPTuners can activate the second PCM pin on the older trucks.
thunder550
Oct 8, 2015 04:53 PM
mr03silverado
Jul 17, 2015 02:15 PM
