My e fan install
Old Jan 7, 2010 | 06:08 PM
  #21
TX Tahoe Z71's Avatar
Sweet. Just got my Nelson harness for my 05 fans in the mail the other day (thanks 1dirtybird), now just need to find a good weekend to put these in.
Old Jan 10, 2010 | 12:28 PM
  #22
crisp's Avatar
Hello all!
New to this scene. Interested in the e-fan conversion. Is this "Nelson" harness from the vendor on the right column? (Nelson Performance?) Is it the "best" way to go, or what other recommendations? (I would like BEST plug-n-play option if possible.)
What is a good source for the '05 e-fans that are repeatedly mentioned, and is that the way to go? What will one pay for this mod?
Thank you for the insights from the thread so far... hope I'm not intruding with these questions too!
-crisp
Old Jan 10, 2010 | 04:14 PM
  #23
neilownz's Avatar
Originally Posted by crisp
Hello all!
-crisp
Yes Nelson Performance. Blackbear also makes one I think.
Old Jan 10, 2010 | 04:16 PM
  #24
SLOXCAB's Avatar
i used a blackbear harness on my install
Old Jan 10, 2010 | 05:11 PM
  #25
GMCtrk's Avatar
The Blackbear harness supposedly uses higher quality relays than the Nelson kit. Several on here have had issues with blowing relays.
Old Jan 10, 2010 | 05:30 PM
  #26
EVILGMC's Avatar
i made my own harness and it works perfectly. followed the diagram posted here and modified it to work with my permacools
Old Jan 10, 2010 | 05:55 PM
  #27
1Bear's Avatar
I ran a PCM For Less harness for about a year before the plug ends of the harness coroded and melted. I then purchased a Nelson harness and it lasted about three years before the relay sockets started melting. I have since purchased another Nelson harness and so far has worked perfect, but so did the last one until the sockets melted. If it eventually dies again, I believe I will try one of Black Bear's.
Old Jan 10, 2010 | 05:57 PM
  #28
SLOXCAB's Avatar
everyone i know that was a BBP harness hasnt had a problem or you could use the wiring diagram that EVILGMC posted and make your own
Old Jan 10, 2010 | 08:41 PM
  #29
crisp's Avatar
Thank you to all for the great feedback and input!
I'll be looking further into these options.
Any suggestions in sourcing of the fans and best brand/approach to take? (I would love a "plug-n-play" affair if there is one!)
-crisp
Old Jan 10, 2010 | 08:52 PM
  #30
SLOXCAB's Avatar
either get the 05 34" radiator with the fans or use your stock radiator with some Ls1 fans
