My DOD AFM Elimination Project
Old Sep 24, 2010 | 04:25 PM
Preston129's Avatar
Great thanks a lot. Do you know if the new one's a MAF/IAT combo just like the ones that came on our 07s?
Old Sep 24, 2010 | 04:51 PM
Mrgoodwrench3's Avatar
Yes it is a MAF/IAT combo, 5 wire plug.
Old Sep 24, 2010 | 04:53 PM
Originally Posted by skolman91
If your sticking with the maf and that little valley filter your going to have un-metered air entering your engine. Not sure on how much but it will be there fwiw..
and what heads are you using?
I have not finalized how I am going to do the PCV system. These valve covers do not have PCV holes or baffles inside. Still thinking of options on how to set it up.
One other thing I did was install a IAT Sensor in the intake manifold. If you look at the picture with the mini K&N it is right above it. I plan to run methanol injection and want to see the actual IAT.
Old Sep 25, 2010 | 04:19 AM
Originally Posted by blsnelling
Nice build. It's cool to see another orange block
I was trying to duplicate a LSX as best as pssible...
Old Sep 26, 2010 | 04:03 PM
Preston129's Avatar
Ever get a chance to measure what the preload was? If 7.4 works on yours it has me rethinking a couple things for mine.
Old Sep 26, 2010 | 10:04 PM
Got the motor running today. Next step is another tune from Justin at Blackbear Performance. The idle is NASTY!! I love it. Here are a few more pictures. I added 4 corner cylinder vapor porting. I ran dual lines to the radiator. Due to the extra tall valve covers I will need a longer plug wire. Just ordered some 10mm's off of ebay.
Cam Spec: 218 /226
595 598
113LSA +1 Advance
111 Intake Centerline
Comp/EPS Lobes
Old Sep 27, 2010 | 08:23 AM
Robert91RS's Avatar
I know Mrgoodwrench3 already knows this but the LS7 cover he mentioned before is the valley cover. An LS7 front timing cover wouldn't fit without a matching crank and oil pump.
Old Sep 27, 2010 | 09:32 AM
Yes you are right. I corrected the list to say "Center valley cover".
Thanks
Old Sep 27, 2010 | 02:16 PM
Robert91RS's Avatar
Thanks
I knew you had just made a typo but I could imagine the potential future threads......"Why wont my LS7 timing cover fit?" lol.
BTW the motor looks sick!
Old Sep 27, 2010 | 02:28 PM
skoal bandit's Avatar
bring her to the track and give us some numbers!!
