my current project
Old Feb 10, 2007 | 10:24 PM
  #21
Quik's Avatar
5 year bitches!
Search isnt working for me on tech right now but basically people were having problems getting the right tq on the crank bolt because of the pulley, I wish I could find the thread. Once the search function starts working again search in the external section for slp pulley problem something should come up about it.
ok i got ya...when i installed a SLP pulley on my old 6.0 thats now in a 02ss it was different. i couldnt get a full 130* degrees on it.. it would just bottom out it felt like. so i just removed it then did the new bolt to 40lbft and called it a day...havent completely torqued mine yet cause of no flywheel on the motor..hopefully tomorrow it will be fully torqued
Old Feb 11, 2007 | 01:03 PM
  #22
Tootall's Avatar
stock rockers?
Old Feb 11, 2007 | 09:37 PM
  #23
Quik's Avatar
5 year bitches!
Originally Posted by Tootall
stock rockers?
stock L92 rockers yes
Old Feb 11, 2007 | 09:42 PM
  #24
Quik's Avatar
5 year bitches!
heres the Liberty proshifted T56, McCloud bellhousing, and a Ram VDS clutch,stock Hurst
Ram VDS Clutch System w/ 900 series disk, pressure plate & billet steel flywheel, rated to 700 hp
Old Feb 11, 2007 | 09:43 PM
  #25
Derek @ EDO's Avatar
FormerVendor
very clean setup!
Old Feb 11, 2007 | 09:52 PM
  #26
SoLow's Avatar
lookn good quik
Old Feb 11, 2007 | 10:17 PM
  #27
Tootall's Avatar
is the bell housing specific for something that you're doing? Did the stock fbody not work with your clutch?
Old Feb 11, 2007 | 10:21 PM
  #28
Quik's Avatar
5 year bitches!
i choose the bell housing cause its a SFI approved. incase teh clutch would ever let go this will protect it from coming thru the floor and cutting off my legs lol
when you go for certain times, they want you to be SFI approved in most applications. for safety reasons... i didnt want to chance a stock bell to hold up to the 408 and launching in the neighborhood of 5k -6500rpms and shifting aroudn 7k to hold up
as for wondering how am i going to hook, thats the biggest dilema right now...once driveline is back in then ill tackle that
Old Feb 11, 2007 | 11:33 PM
  #29
Tootall's Avatar
track bars, 4 link . . . roll cage?
Old Feb 13, 2007 | 02:02 PM
  #30
Scream's Avatar
MOOBIES Moderator
I'm curious about the A/C compressor and the alternator. I have all of the F-car brackets, and even a PS pump and reservior, but I wasn't sure if my A/C compressor and alternator would work w/ the new brackets, or if you have to get f-car specific pieces?
