my 383 build thread
Old Mar 3, 2014 | 08:18 PM
  #311
BigDaddy0381's Avatar
yes sir, sounds meaty.
Old Mar 3, 2014 | 09:14 PM
  #312
greasemykey's Avatar
wednesday i will have my jakes stage 3 80e and my billet circle d 3600rpm stall. all i need now is the correct slip yoke and u joint and i shall be able to drive my baby again. well until i break something else.
Old Aug 10, 2014 | 02:13 PM
  #313
3000 miles later and its metal on metal knocking. new question. the crank and rods are the same as what is used in the 408 stroker correct? im going to get a 6.0 block and 408 pistons and rings and start over. going to sell the PRC heads for a set of AFR heads.
Old Aug 10, 2014 | 02:59 PM
  #314
oakley6575's Avatar
Do you have it torn apart already? How do you know the crank and rods are in good shape?
Old Aug 10, 2014 | 03:03 PM
  #315
nope im getting a bore scope tomorrow to look in the cylinders. it was more of a can i reuse what i have with the exception of the pistons and rings. i can always have the crank polished when i have the new pistons balanced with the rotating assembly. just trying to see what i have to buy before i pull the engine. i may end up just having a broken valve spring or a dropped valve which is what it sounds like when its running.
Old Aug 10, 2014 | 06:43 PM
  #316
RezinTexas's Avatar
yes, a 408 is same rods and crank as 383.
Sorry to hear you are having troubles. Let us know what you find out.
Old Aug 10, 2014 | 07:47 PM
  #317
once i get the valve covers off and take pictures of the cylinders i will know what im looking at. wife said to scrap it build a 8.5:1 compression 408 with a maggie on it and quit my bitching. i cant imagine that i did anything wrong building it if it lived 3000 miles and survived 4 dyno pulls.
Old Aug 11, 2014 | 07:30 PM
  #318
well i scoped the cylinders and #5 has a low hanging valve in front of the spark plug hole. guess the head is coming off. i hope the spring is broken and the piston is still ok.
Old Aug 13, 2014 | 06:43 PM
  #319
so i have decided to buy a new set of heads. seeing as how the PRC heads i have fell apart what should i buy that will compliment my engine and cam choice?
Old Aug 24, 2014 | 09:07 PM
  #320
WICK3DxGATA's Avatar
nice build. but i got some questions for you if you dont mind answering it would be great.
how do you like the 383 as a daily driver?
where would you recommend to get the rotating assembly to do a 383?
