This is a MUTT!
Old Aug 23, 2007 | 01:40 AM
jimmydong00's Avatar
Question This is a MUTT!
Does anyone know if a nv3500 will hold up to a fairly well built 400 rwhp LT-1? Also, Would it be a good swap into a 1992 ext.swb chevy.
Old Aug 23, 2007 | 06:51 AM
Dock Rocker's Avatar
it will hold up but I think you will have the low gearing unless you are pulling a trailer. If I were you I would just swap in a t56. That is my plan.
Old Aug 23, 2007 | 07:26 AM
Default mmmmm...six speed.
A six speed shifter wont line up with the factory hole will it? Besides every time I track one down at a decent price I am a minute late and a dollar short. How low of a gear are we talking?
Old Aug 23, 2007 | 09:14 AM
That trans is for a 1 ton truck so the gears are really low. First is almost a granny gear. They are strong transmissions and are fairly cheap. The bellhousing is the same and they will match up. If you go with the 6 speed in a truck you will have to lower the rear gear as that trans has a double overdrive. so a search on 6 speed swap that will help.
Old Aug 23, 2007 | 10:58 AM
Isnt the nv4500 for 1 tons? I thought the nv3500 was for the v6 and v8 1/2 ton trucks.
Old Aug 23, 2007 | 11:05 AM
The nv3500 is the tranny that came with my truck. I bought the truck with the v6 pulled out and in bags, so I assume that is the original trans. Having a lower final drive is cool. It will leave harder as long as show some love to the rest of the driveline. I am not too familiar with the particulars with the 88-98 trucks. More of a 72-87 and 99-current body styles nut.
Old Aug 23, 2007 | 05:53 PM
I am almost sure the getrag is what comes in the 1/2 ton trucks
Old Aug 23, 2007 | 06:33 PM
Red04Silverado's Avatar
1/2 ton!
Old Aug 23, 2007 | 07:08 PM
Originally Posted by Red04Silverado
1/2 ton!
Old Aug 23, 2007 | 07:29 PM
nightrunner's Avatar
Mr. Obvious
the new venture NV3500 is what comes in the 99-04 gm fullsize trucks with a manual trans and either the 4.3L v6 or the 4.8L v8. gm swapped to the tremec TR-3450 in 05-07 and dropped the man. trans option in NNBS 07(99% sure)
the new venture NV4500 is the 5speed that comes in the HD trucks with the 6.0L v8
this is all based on the 99-06 NBS gm trucks, may or may not be applicable to the 88-98 OBS trucks
