This is a MUTT!
A six speed shifter wont line up with the factory hole will it? Besides every time I track one down at a decent price I am a minute late and a dollar short. How low of a gear are we talking?
That trans is for a 1 ton truck so the gears are really low. First is almost a granny gear. They are strong transmissions and are fairly cheap. The bellhousing is the same and they will match up. If you go with the 6 speed in a truck you will have to lower the rear gear as that trans has a double overdrive. so a search on 6 speed swap that will help.
The nv3500 is the tranny that came with my truck. I bought the truck with the v6 pulled out and in bags, so I assume that is the original trans. Having a lower final drive is cool. It will leave harder as long as show some love to the rest of the driveline. I am not too familiar with the particulars with the 88-98 trucks. More of a 72-87 and 99-current body styles nut.
the new venture NV3500 is what comes in the 99-04 gm fullsize trucks with a manual trans and either the 4.3L v6 or the 4.8L v8. gm swapped to the tremec TR-3450 in 05-07 and dropped the man. trans option in NNBS 07(99% sure)
the new venture NV4500 is the 5speed that comes in the HD trucks with the 6.0L v8
this is all based on the 99-06 NBS gm trucks, may or may not be applicable to the 88-98 OBS trucks
