MSD boxes worth the dough?
Old Jun 27, 2011 | 12:42 AM
lukn4trbl355's Avatar
Default MSD boxes worth the dough?
hey yall just thought id ask a quick question, due to LS powered motors i know their ignition systems are pretty good from the factory, i was just wondering if id benefit any response/power from goin with an msd box like the msd 6AL or the one specifically for the ls motors. if so should i have my tuner take out factory rev limit and just use the pills msd has or what would be best?
thanks for your time
tj
Old Jun 27, 2011 | 12:51 AM
Mangled03gmc's Avatar
Baltimore Whore
Not worth the time money or effort imo...
Old Jun 27, 2011 | 09:51 PM
00buckshot's Avatar
I use one and love it pal..............................
Old Jun 28, 2011 | 02:46 PM
You cant use a 6AL box on these motors.
You would have to buy 2 of their modular or digital boxes to make it work.
I highly doubt $800+ is worth it when the ignition system is far superior than the past days of single coil on distributor.
Plus, it was never noted by any article that I can recall of the LS based engines suffering from a weak ignition system.
I would put the money towards something else.
Jim
Old Jun 28, 2011 | 03:08 PM
Post
Plus,
If you check out their website they do not offer an ignition system for our vehicles.
They do offer DIS (Distributorless Ignition Systems) boxes for LS based engines that are carburated, but not EFI or MPI. Basically, you would have to have a stand alone ECU to run everything except the ignition system.
I know they use to offer the digital boxes that controlled up to 4-6coils all in one box, but I'm not seeing them anymore. However, it would still require you to purchase 2 of those boxes.
Now, the only thing that that do offer are the 8 replacement MSD coil packs and possibly the plug wires.
From past reviews, the 8 coil pack MSD replacement kit was not worth the money spent on them.
Its up to you, but be prepared to fork up some $$$$ for this so called upgrade!
Jim
Old Jun 28, 2011 | 03:45 PM
Coban's Avatar
It's not really worth it even on older engines...
Complete waste to upgrade the ignition system in any way on these vehicles.
Old Jun 28, 2011 | 04:37 PM
Baltimore Whore
I am guessing you would have to love it, so you can justify spending that kind of money on it..
As far as having the 6al, 7al box vs a old type of ignition, coil systems, I would say yes def a upgrade, being it will make and send, keep the volts up through out the longer run. Being our trucks, are using the coil packs, you have a plug wire that is so short, your not going to see a difference between on of them and stock ones..
Old Jun 28, 2011 | 05:26 PM
TXoldskool's Avatar
I have a 6LS-2 (4x/58x) running my LY6. It shows that if I want to hook it up to an efi system you just need a special cable (which I bought and didn't need for carb'd) and control timing. It also allows you to use its 2 step limiter for staging, nitrous or whatever.
If anyone goes this way with an efi motor....I'll make you a great deal on the 6LS-2 cable (doesn't work with 6LS?) for it!
Old Jun 29, 2011 | 01:04 AM
damn well now i feel like a ree ree for askin that lol, just thought itd be worth a shot, made a nice difference in response on my nova, i was like hmm mabey truck? either way im an idiot lol, and thanks for the input guys i appreciate it!!!
Old Jun 29, 2011 | 07:09 AM
00buckshot's Avatar
Only reason i have one is because im runnin a carb, Just to try something different and i actually love it, so dont bash me cause i converted, i still have all my efi stuff if i ever wanted to change back to it
LARRY01Z28
28
Sep 28, 2015 07:54 AM
2plus2
Sep 13, 2015 07:17 PM
cousblake11
Sep 9, 2015 06:52 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
jtphelps289
Sep 1, 2015 09:11 PM
