mount catchcan at an angle?
Old Oct 17, 2009 | 08:52 PM
  #31
GMCtrk's Avatar
Originally Posted by BlackGMC
What does that even matter, who cares about FP when the truck is not running... what you should care about is the 10psi drop when yours is running... But i agree 58 at WOT is awesome!!!
You do understand how the FPR works, right? With the engine off there is no vacuum. One the engine is on, there is vacuum and the FPR decreases pressure accordingly. The pressure with the engine off is key because it tells you if the pump is priming correctly. If not, you got a bad pump.
Old Oct 17, 2009 | 08:59 PM
  #32
BlackGMC's Avatar
Resident Retard
Yes i know how it works... I understand that it is supposed to vary, that is why your injector flow rate table looks like a diagonal... Personally i would like to run more pressure, but it is your truck...
Old Oct 17, 2009 | 09:01 PM
  #33
GMCtrk's Avatar
It's what it's supposed to be running. I don't see why I'd need to do anything about it.
nabozny21
Oct 17, 2015 07:47 PM
thewrx
Oct 6, 2015 10:59 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
old motorhead
Sep 29, 2015 08:22 PM
DrX
Sep 29, 2015 04:31 AM
