More Power
Old Jun 23, 2005 | 02:27 PM
  #31
01Blackerado's Avatar
good find dude
Old Jun 24, 2005 | 05:44 PM
  #32
moregrip's Avatar
what a rush!
hmm, my alternator only uses two wires in a 4 wire plug, maybe its an 05 thing, if thats the case, I may just need the plug for this to work for me....
Naked, why don't you let me borrow that alternator for a couple of years?
Old Jun 24, 2005 | 05:47 PM
  #33
Mr. Sandog's Avatar
Sure....MSRP and it's yours!
Old Jun 24, 2005 | 05:50 PM
  #34
moregrip's Avatar
what a rush!
we need to talk oh wise(***) one....
Old Jun 25, 2005 | 05:35 PM
  #35
moregrip's Avatar
what a rush!
found this on a alternator website: and no I wasn't going to retype,
2005 CHEVY TRUCKS, SUBURBAN, TAHOE,YUKON 4.8L,5.3L,6.0L AND S-10 W/4.3L, BLAZER,Duramax Diesel 6.6L,HUMMER, H2 6.0L, ALL VORTEC ENGINES V6 AND V8! ALL TRUCKS WITH 2 PIN REGULATOR. PLEASE CHECK THE NUMBER OF PINS IN THE REGULATOR HOUSING BEFORE ORDERING. ORDER THIS ALTERNATOR ONLY IF YOUR ALTERNATOR HAS A 2 PIN REGULATOR MOLDED PLUG! THERE ARE 2005 'S WITH THE 4 PIN PLUG DESIGN, BE SURE BEFORE YOU ORDER!
Old Jun 25, 2005 | 10:24 PM
  #36
KySilverado's Avatar
I installed the tranny temp gauge in my cluster. Possible with the Tahoe unit?
Old Jun 26, 2005 | 02:38 AM
  #37
Mr. Sandog's Avatar
From Page 32 of that PDF file I linked to, it looks as if there is a blank spot where a stock tranny temp gauge might go - just like where other guys (you?) have put aftermarket 2 1/16" gauges. So it could work. I still do not have a part number for this cluster, however.
I still have some feelers out on this wiring issue. On my stock alternator, I have a 4-pin connector with three of those pins populated by wires. If all three wires need to be hooked up, I may have to get rid of this 160A alternator.
Old Jun 26, 2005 | 07:58 AM
  #38
Not an aftermarket gauge. Bought a kit and soldered the actual OEM gauge to the cluster PCB. Factory look install. If there is a blank spot I bet this kit will also install in this cluster.
Old Aug 8, 2005 | 02:12 PM
  #39
OKLAGMCRUISER's Avatar
the plug appears to be different than that on my 99 nbs...fyi.
andrewlong
Nov 9, 2016 09:38 AM
Superman09
Sep 25, 2015 05:55 AM
Brandonlflr12
Sep 9, 2015 03:54 PM
andrewlong
Sep 8, 2015 10:25 PM
