more engines questions cus im bored
Old Jul 3, 2007 | 03:11 PM
perrco's Avatar
Default more engines questions cus im bored
ok i have a 2000 rcsb with tha 5.3l but im thinking about doin a engine swap. will this new 6.2l work http://www.crateenginedepot.com/stor...-P1821C53.aspx
Old Jul 3, 2007 | 05:26 PM
gmtechnician's Avatar
the 6.2L have a cam actuator and DOD. you will have to have a totally new wiring harness and PCM.
Old Jul 3, 2007 | 07:02 PM
One_Slow4.8's Avatar
there are a few differences crank reluctator(SP?) wheel and the cam sensor and the knock sensors are different but if you got a new pcm and wiring harness then i cant see why it wouldnt work. but it sounds expensive and not worth the time and money, you could prolly get a built 6.0 or maybe even a 408 for as much as it would cost to put one of those motors in.
Old Jul 4, 2007 | 12:45 AM
perrco's Avatar
ya that was what i thought. i mean its is only 400 dollars more then the 6.0 so im was just wondering. plus its only like 3 more horsepower. im just going to go with a 6.o and a t 56
Old Jul 4, 2007 | 02:05 AM
Bo185's Avatar
Find a 6.0L short block, stroke it to a 408, and build it using your accessories. Also get a set of L92 heads and intake with a nasty cam! You now got a nice setup for cheaper than $5800!
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Sep 30, 2015 10:34 AM
USMCvet0311
Aug 1, 2015 07:45 AM
Alco
Jul 25, 2015 01:47 PM
4B11T
Jul 13, 2015 03:48 PM
