more boost
Old Feb 8, 2005 | 05:44 PM
Prochrgd5.3's Avatar
Default more boost
I would like to know how what would be a safe boost level more a stock bottom end. I am now running 9 pounds on a procharger P1SC kit. I had planned on finding some 6.0 heads and some 48lbs injectors and a smaller pulley and was wanting to run 15lbs of boost but would like to know if anyone is running this much boost on a stock bottom end with any problems. thank you.
Old Feb 8, 2005 | 05:47 PM
parish8's Avatar
single digit dreamer
depends on you idea of safe.
if you run race fuel and get the tune on i would say it is "safe". tuning is the key, watching for knock and leting off if you see/hear any and i think it would take it fine.
Old Feb 8, 2005 | 11:11 PM
Black Blown 02's Avatar
9psi could be unsafe without a good tune. You could probably go 12+ psi pretty safely with a good tune.
I'm running 11psi with a 3.6 pulley right now. I have a 3.4 pulley that's going on after it warms up. I can't find a belt small enough to get a smaller pulley than a 3.4.
The first thing you need to do before upping the boost is get a better flowing intercooler. The stock ATI unit is a serious restriction even at 9psi.
Old Feb 8, 2005 | 11:14 PM
F8L Z71's Avatar
What Parish said..
The problem is not knowing what HP you'd be at with 15psi.. Since PSI is simply a measure of restriction you could be running way less or way more HP than someone else with the same PSI..
Tunning is going to be critical IMO and I doubt you can do it without race gas or methanol.
Not saying you can't but I wouldn't mix in the word safe. Hehehe
Keep us posted man. We need more high HP ATI guys in here besides Black Blown 02 and Greentahoe
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
