Modding a 4.8L
Old Jun 8, 2009 | 10:33 AM
  #21
SpeedDensityZ's Avatar
11 Second Club
I really appreciate all the useful info. Is that cam a custom grind or something off the shelf? I want it a little choppy like you said but nothing crazy. I haven't done much reasearch on actually how a cam works. The LSA you listed is 110+4, 4 is the amount of advance that is degreed into the cam? Also, does anyone have some dyno numbers with this cam or any 1/4 times? 212/218 .558/.563 110+4...
Old Jun 8, 2009 | 10:35 AM
  #22
BlackGMC's Avatar
Resident Retard
That would be a custom grind... And Yes the +4 is the amount of advance ground into the cam... As far as i know, i have never seen anyone with that cam..
Old Jun 8, 2009 | 10:45 AM
  #23
LaSinister's Avatar
I'm running a TSP 220/220 .581/.581 at 111 LSA, and woke up the 5.3L real good.
What I noticed with this LSA is that my midrange is very strong. I have the stock stall and the RPM drop between shifts is not that significant. It pulls strong and it isnt crazy choppy.
I recommend this costum grind cam.
Old Jun 8, 2009 | 10:50 AM
  #24
I run the comp xr265 high lift I love it, but I'm pretty sure I should run a 3k to a 3200 stall. I would go with what blackgmc offered, it should make good low end and pull good throughout the rpm range.
Old Jun 8, 2009 | 11:00 AM
  #25
11 Second Club
With this cam I will also need 918's right?? Would I need new pushrods? If so, what size? I'm just looking for a cam that will meet my goals. 13sec qtr. and a good DD.
Old Jun 8, 2009 | 12:27 PM
  #26
budhayes3's Avatar
PT's Slowest Truck
I would go with the PAC 1218's over the Comp 918's due to everything that I've read about the Comp's breaking. I recommend some good hardened pushrods for cheap insurance, although there's always some debate in reference to their necessity...
Old Jun 8, 2009 | 02:18 PM
  #27
mcfarlnd's Avatar
Un-Registered User
i wouldnt do any kind of spring besides duals. too many others break, even the "revised" 918's.
Old Jun 8, 2009 | 02:23 PM
  #28
BlackGMC's Avatar
Resident Retard
+1!!! I feel warm and fuzzy with my duals shifting at 7k occasionally and 6800 regularly...
Old Jun 8, 2009 | 10:53 PM
  #29
I Drive a 4.8's Avatar
Hey BlackGMC, just wonderin' where you have your cams ground at? I was thinkin' about getting ahold of Crower to grind me up one... maybe you or someone else can throw some light at me if there's a better price-for-the-product vendor. Much obliged.
Old Jun 9, 2009 | 11:11 AM
  #30
budhayes3's Avatar
PT's Slowest Truck
Corey, you're running a Flowtech/Ed Curtis cam now, right?
