mod selection ?
Old Mar 5, 2013 | 04:46 PM
ls1prayer's Avatar
Default mod selection ?
I have 4.8 chevy single cab and I just got a 5.3 motor to swap in it. Now the goals I have I think are simple for what i want as a dd.
#1 goal
lay down 330whp (fingers crossed budget build) in my daily just so that its a fun truck. I work with the 5.7 motors alot at work but no pretty much nothing about the 5.3 motors.
my mod list so far
lt headers -y pipe no cats
small cam that would let me keep my stock stall and stock valvetrain
cai
hwy tune
? is what grind cam would I need so that I have a slight lope and that is not to big for my 5.3 and also this motor having 145k im sure to swap out the water pump and some other stuff just because it easy to get to out the truck. Anybody thats landed near a little over 300whp please chime in I know the 5.3 is a great motor but I am pretty sure its gonna take alot more to get up like a 5.7. I have been reading but havent seen any good right ups on throw in camshafts wthout changin anything else.
Old Mar 5, 2013 | 07:39 PM
darnie's Avatar
if your looking for a good streetable cam the tr 220 or 224 cam but it depends on what converter you wato run as well. thats just a off the shelf cam. if you want you could also get like a pat-g custom spec cam. bolt on's with a cam should get you over 300 to the ground. if you didnt wanto use a new converter id run this
Comp Cams 212/218 LSx Cam "LOW LIFT"
or this
"TR 220-112" - 220/220 .551/.551 112 LSA
Old Mar 5, 2013 | 08:19 PM
jrmchevyman's Avatar
You're going to need new springs regardless and I would also get hardened pushrods at the same time.
You can use LS6 springs on certain cams with low lift. The LS6 springs are very cheap. On the 212/218 low lift cam you could run the cheap LS6 springs.
I probably wouldn't run the ls6 springs on the Tr220 cam as they don't have quite enough seat pressure imo.. Some people have gotten by with them, but I recommend getting some pac1218's, PSI, Manley, brian tooley, or similar around .600 lift max.
Old Mar 5, 2013 | 08:42 PM
ltr450ryder's Avatar
I go with the 212/218 but if he got the modified tbss stall it would still be perfectly streetable and run alot better. U can get 330 rwhp from a cam only 5.3 but 2wd I made 380 in my 2wd 5.3 heads and cam tho and I had a bigger cam for a 5.3 and or prc heads
Old Mar 5, 2013 | 09:01 PM
darnie's Avatar
im runnin the ls6 springs with the tr 220? no issues bout 8k on them so far?
Old Mar 5, 2013 | 09:17 PM
ls1prayer's Avatar
tbss stall? and the 212/218 does it have a decent lope? not the most important by any means just a ? And i am guessing these motors are like the ls1 motors when it comes to being just as good with high miles and a cam?
also thanks guys for the imput and out of curiousity what kind of mpg u guys getting tuned and a mild cam?
Old Mar 5, 2013 | 09:22 PM
Get that can on a 112 lsa it'll lope some and a tbss stall us a 278mm trucks have 300mm and there stall us like 22-2400 truck us 1600ish
madmann26
Apr 29, 2020 09:17 AM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
bisqikss
Sep 27, 2015 09:40 PM
