milling 317s to match 243's cc
Old Mar 12, 2008 | 09:56 AM
Tootall's Avatar
Default milling 317s to match 243's cc
any one done this or something similar?
I'm wanting to get some heads for a LS1 5.7 bore. (5.3 bored to a 5.7)
I'm trying to get around paying a higher price with the 243s. This is a budget build for a 2000 s-10 project. I want to use a 226 Patriot cam. I'm wanting 64cc chambers, just like the 243s, but without the price.
So far I'm using stock flat top Ls1 pistons, and that's it. It's either the milled 317s, or do some home ported/milled 241s.
I currently have both sets of heads. (317 and 241)
Old Mar 12, 2008 | 10:01 AM
silver-mod-o's Avatar
Hunt&Fisherator
mill the 317's IMO... any power adders?? whats the rest of the setup gonna look like??
Old Mar 12, 2008 | 10:06 AM
joshua022's Avatar
That would require alot of milling, probably so much that it would start to hurting the flow of the heads. 72cc to a 64cc is a big jump.
Old Mar 12, 2008 | 10:12 AM
bluecajun5.3's Avatar
11 Second Truck Club
if the engine is going to be forged, you could do some domes to bring back up the c/r with the 317's and leave the chambers stock.
Old Mar 12, 2008 | 10:33 AM
Tootall's Avatar
no other power adders, 4L60e trans, 4.3, single cab, 2-4 drop
that's what I figured, but I'm more worried about the valves hitting the sides of the piston walls. I've already seen this on a set of heads . . . . (member on here)
he's settled on some flat top, Hypernutechnic (not forged) pistons.
Old Mar 12, 2008 | 10:41 AM
Hunt&Fisherator
you should be fine with the LS1 bore... the 241's work well but it taked a lot of porting to make them flow like a 317...
Old Mar 12, 2008 | 10:49 AM
joshua022's Avatar
Have you tried trading the 317s for some 243s, someone maybe going F/I and needs a lower CR.
Old Mar 12, 2008 | 10:54 AM
Tootall's Avatar
nah . . . nothing yet. I would really like to have some of the Patriot heads
Old Mar 12, 2008 | 11:07 AM
TXsilverado's Avatar
425 will get you new 243 castings and stock ls1 valves from patriot. thats as budget as it gets i think...or you can come pick up my 853 heads for 50bux if your budget is that tight.
Old Mar 12, 2008 | 11:17 AM
Tootall's Avatar
hahah not that tight, but I'll give him a call and see what he can afford.
Here's the guy's truck that it's going in.
