Methanol Injection
Old Feb 24, 2005 | 10:28 AM
  #21
Weedo's Avatar
As I'm getting the STS setup, I just ordered their Meth Inj. Seemed easier.
As far as power, Xtreme tested their truck at around 30hp increase with the Methanol using windshield washer fluid (30% Meth).
Anyone else tested their power gains?
Old Feb 24, 2005 | 10:29 AM
  #22
greentahoe's Avatar
Originally Posted by moregrip
Look at aquamist, they have some very nice, although expensive, setups, you could get away with water inj day-to-day and then switch it up to a 50/50 at the track.
Problem with doing that is that the tune to run water would need to be much more conservative than the one with alky. Also the Alky affects A/F ratio. Alky and meth are cheap enough where it really isnt an expense. You can get large amounts from a place called hyperfuels or something like that. I just buy the cans of alky from Home Depot. $10 worth of alky lasts 3+ weeks.
Old Feb 24, 2005 | 10:31 AM
  #23
moregrip's Avatar
what a rush!
that sounds pretty reasonable. do you run it full test or mixed?
Old Feb 24, 2005 | 10:33 AM
  #24
greentahoe's Avatar
01_5.3_RCSB got like 50 rwhp from his meth setup! Thats on an intercooled Paxton (same as Vortech). I havent gotten any tuning done, but I have been able to run 5-6 more # of boost with the same timing with the addition of alky. Im sure there is more left when I turn up the timing a bit.
  #25
greentahoe's Avatar
Straight denatured alky. Mixing it made less power. Meth seems to make the most power though.
Old Feb 24, 2005 | 11:57 AM
  #26
Yellowsierra's Avatar
The cool thing about the snow performance kit is that for $399.99 you get the varible controler or the plain kit for $299.99. I think this is which kit I'm going with.
lator
Yellow
Old Feb 24, 2005 | 12:11 PM
  #27
Weedo's Avatar
Where are you all buying your Methanol?
Old Feb 24, 2005 | 12:21 PM
  #28
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by DanaliHD
i have a SMC kit in my truck but don't use it. so far, i can't see that it is worth using. i don't get any more hp or torque by increasing the timing and using the alcohol than i do by keeping the timing lower and not using the alcohol.
The point of meth inj isn't really running more timing but in running higher boost at the same timing.
Old Feb 24, 2005 | 12:23 PM
  #29
I AM A MOTHERF*CKER
right, why run the methanol though? On a street vehicle wouldn't it be easier to run water inj than methanol on a daily basis?
Meth gives you octane + cooling, water gives you better cooling.
Running water is safer in terms of fire hazard, but I don't use the meth much on the street anyway (and leave the tank relatively empty).
Old Feb 24, 2005 | 12:28 PM
  #30
ok, i have mine running very good now at 8lbs boost and no alcohol. i get 0 kr. if i were to put the 10lb pulley on, are you saying i can leave the tune exactly the same but just turn on the alcohol? i'll give it a shot. at what boost should i have it turn on? also, without a wideband, it's impossible to keep the a/f in check because the more you turn up the alcohol to decrease the kr, the more out of whack the a/f gets. almost not worth the effort.
