Manifold Bolts
Old Sep 16, 2010 | 03:00 PM
Lucille's Avatar
Default Manifold Bolts
Are the exhaust manifold bolts reusable on the NNBS truck or have they swapped to torque to yeild like everything else?
Old Sep 16, 2010 | 04:32 PM
RibeiroBJJ's Avatar
Praise The Lowered
They are re-usable..I helped a friend put headers on his 09 and we re-used his no problem......
Old Sep 16, 2010 | 05:49 PM
KleenHall's Avatar
they break pretty easily so use caution
i replaced all of mine just for some piece of mind
Old Sep 16, 2010 | 05:58 PM
02'Z71ONDUBZ''s Avatar
x2, not worth the if they break off.
Old Sep 16, 2010 | 06:20 PM
outlawz2004's Avatar
I reused mine. Three years now without ever having one come loose.They were better than the bolts that came with the headers.
Old Sep 16, 2010 | 07:05 PM
fletchermotorsports's Avatar
We see a ton of trucks come into work with the stock ones broken. Personally i had 4 broke on my 6 liter I replaced them with stock ones and no more issues. personally wouldn't reuse factory ones.
Old Sep 16, 2010 | 09:49 PM
BuyAmericanIron's Avatar
Don't even consider reusing them. I highly recommend replacing them with OE or better yet, use the GM studs many others on this site have used. Do a search and you will find them.
Old Oct 19, 2011 | 12:07 PM
LJO's Avatar
LJO
Definitetly get new ones! Or do the stud upgrade.
Old Oct 19, 2011 | 12:47 PM
budhayes3's Avatar
PT's Slowest Truck
I'd like to know who supplies (or supplied) Gibson with their shorty header bolts, as I used mine on my shorties for 5+ years, and when I removed them to install my StainlessWorks LT's, they were in such good shape, that I didn't use the Stage8's that I had bought but rather reused the Gibsons. They've been on the engine for 10+ years now. Granted, they got a good coating of anti-seize on the threads, but the 12mm heads are still in great shape also, with just minor surface rust. It's my assumption that the bolts are stainless as the shorties were.
jfuegner
Dec 22, 2016 03:47 PM
lxcoupe
Aug 24, 2015 08:16 PM
JFortner5
Aug 20, 2015 06:13 PM
fat tony157
Jul 16, 2015 12:35 PM
