Major Issue..NO SPARK...HELP!!
TOTM: June 2007
long story short, nelson intruction dont say which green, out of the three to hook up the ac compressor turn on for there efan harnass...hooked it all up, turned the key and it sparked. Took it off, went to test hte wires again...
Fuel pump cycles, starter works....but we have no spark???
I have checked all the fuses twice, and the big fuses all click and seem to work whent eh trucks on..yet it recieves no spark...What do I do????
Originally Posted by DLH2006
do you have one with a white stripe? if so try that one.
*OH and so far I've bought 2 harnesses from DLH2006 and both have been PERFECT*
Originally Posted by RandomHero
ORLY? My 99 used the solid green one without problem and it works great.
Thanks man!
mine is the solid green wire as well but i believe some may be different
if you want to be sure look down by your AC comp, you will see a plug that has two wires. The green wire is the one you need to splice into,look for that same wire up alongside your alt. in the wire loom.
Originally Posted by bgray
fingered it out..my buddy didnt quite have the PCM plug in properly..i guess it didnt read enough to start!
Glad to hear you got it figured out
