lt's and low end loss
Old Mar 25, 2008 | 08:28 AM
timmer1's Avatar
Default lt's and low end loss
Hey guys, I just put some lt headers on my truck and seem to have lost a bit of low end power. I know that it was supposed to gain high end, but didn't know I'd lose so much low end. Used to have to be careful taking off, so I didn't spin tires, but now it can't when I mash it.
Old Mar 25, 2008 | 08:31 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Did you re-tune after the header install?
Old Mar 25, 2008 | 10:14 AM
dlt76028's Avatar
somethings wrong? you should gain a good amount of torque with LTs. I felt a difference everywhere right after my install.
Old Mar 25, 2008 | 10:58 AM
Moddoo's Avatar
Ditto
My money is on "NO"
LTs will gain a noticeable amount down low.
Old Mar 25, 2008 | 11:00 AM
outlawz2004's Avatar
I felt I had a little loss from a stop also with the longtubes. Once rolling, it moves out, but it did move my power band up a little. In the upper rpms, it pulls way harder than before. I always thought it was because I have the loudmouth muffler on there, going to a magnaflow soon to try to get back a little low end and also to quiet it down.
Old Mar 25, 2008 | 11:44 AM
Dark Halo's Avatar
I can bust loose from a stop and They will even but loose if I mash it at 30+mph no loss and all gain here
Old Mar 25, 2008 | 12:23 PM
dlt76028's Avatar
that might have something to do with the lq9
Old Mar 25, 2008 | 12:49 PM
RedHot04's Avatar
headers can be tuned based on the length of the collectors. Longer or shorter makes a difference, make a mark lenghtwise on the collectors with a crayon or grease marker and take it on a hard run then check the mark. Where ever the mark burns down to is where you want to cut the collectors at. Here is a link to a discussion on this:
https://ls1tech.com/forums/showthread.php?t=69745
Old Mar 25, 2008 | 12:51 PM
RandomHero's Avatar
You won't necessarily gain low end. In fact you'll probably lose quite a bit of low end if you're running a 4.8 or relatively stock 5.3L.
The problem is that you probably went with pacesetters which have 1 3/4" primaries which are great for modified trucks, but terrible for stock truck which see very little top end. You probably gained quite a bit up top, but you almost for sure will lose low end.
Old Mar 25, 2008 | 01:06 PM
thats what I got, pacesetters.
