lt1 fans are in!
well i put in my lt1 fans today.
instal went pretty smooth i have a thermo switch and an over-ride switch so far so good,
definetly a little more umpf off the line but didnt get much whhel time today either,with stock t-stat i'm running about 5-10 degrees cooler(guessing according to gauge)
still need to wire a hot switch to run one fan to cool down if the truck is off, like sitting in the staging lanes
hope to have some pics tommrorw
thanks for eveyones help and very helpfull pics in the other threads
keith
keith
pics
<img src="http://www.imagestation.com/picture/sraid24/p9c22f0c6790bf9358ac3cf106150cb44/fd91283d.jpg" alt=" - " />
<img src="http://www.imagestation.com/picture/sraid24/p192eef2f88283e25a04e7af32b725613/fd91283b.jpg" alt=" - " />
thermo switch and realy
<img src="http://www.imagestation.com/picture/sraid24/p34f3fd7929ccecb13889d5275d892597/fd910aba.jpg" alt=" - " />
fans are from a 94 trans am
not bad maod for $120 for everything
got the fans for 75
relay/tsat setup with wiring 35
and another 10 for misc, crap
<img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" />
got the fans for 75
Kent I used LS1 fans from a 2000 TA. They are almost the same as LT1. I used some bedframe corner brackets I had laying around in the garage. They work perfect but I need to cut off the excess metal and paint them black. After cutting the brackets, I hope to be able to fit the top part of the shroud back on to hide the fans and my ugly ghetto wiring.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CashDudeHomie:
<strong>Kent I used LS1 fans from a 2000 TA. They are almost the same as LT1. I used some bedframe corner brackets I had laying around in the garage. They work perfect but I need to cut off the excess metal and paint them black. After cutting the brackets, I hope to be able to fit the top part of the shroud back on to hide the fans and my ugly ghetto wiring.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks, I just saw some on Ebay that I might bid on. What kind of wiring is needed and where do I get it? Kent.
yes you can use ls1 fans too just that these were easier to come by for me
brackets are simple enough to make .
mine are from an old set of fog lights that i rebent to waht i needed
as for the wiring i got a thermo switch and relay setup at autozone and had anoter switch(overide) lying around and then some basic wire splices and connectors
<small>[ July 08, 2002, 11:42 AM: Message edited by: 01badgmc ]</small>
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
Wrecker 426
Sep 30, 2015 09:39 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
