lt pacesettler y pipe need help quick
Old Nov 20, 2010 | 04:15 PM
kvpaintbal's Avatar
Default lt pacesettler y pipe need help quick
I got th e headers on I can't get the y pipe on to the header its to tight of a fit what do I do
Old Nov 20, 2010 | 04:52 PM
dmelvin's Avatar
You could do a very very small pie cut. just be sure that you use a rubber mallet to slip the Y all the way up past the end of your cut.
If you're able to get the Y on a little bit, then you could use a rubber mallet to finish tapping it into place.
Old Nov 20, 2010 | 05:16 PM
budhayes3's Avatar
PT's Slowest Truck
Or you could just run open headers
Old Nov 20, 2010 | 06:22 PM
gs7793's Avatar
haha running open headers isnt a bad idea!!
Old Nov 20, 2010 | 07:01 PM
kvpaintbal's Avatar
I got them now, the y pipe way to tight of a spot they should build the part that comes around to the driver side a. Little longer before the bend
Old Nov 20, 2010 | 07:02 PM
budhayes3's Avatar
PT's Slowest Truck
Did you have to cut a slot or how did you get them on?
Old Nov 20, 2010 | 09:28 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
my Y pipe touches my cross member????
Old Nov 22, 2010 | 07:22 AM
kvpaintbal's Avatar
Mine does too, I cut some of the y pipe and finally got it on
Old Nov 25, 2010 | 07:25 PM
baSICK5.0's Avatar
Mine was a nightmare. And mine was in several pieces. I almost removed the crossmember to get it right. Still needs to be redone. Leaks like a faucet.
Old Nov 25, 2010 | 07:35 PM
viciousknid's Avatar
Where's the Beef?
I heated mine up and used a pry bar to move it on further to get it off of the cross member. Probably wouldn't hurt to remove the cross member and flatten the y pipe out a bit right there with a BFH.
03sierraslt
14
Oct 9, 2015 05:53 AM
Wrecker 426
Oct 7, 2015 12:11 PM
BlownHD
Oct 3, 2015 12:24 PM
kmcn47
Sep 17, 2015 01:12 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
