lsxrt fuel injector o-rings (HELP)
Old Jan 23, 2011 | 06:35 PM
Boosted_Silverado's Avatar
Default lsxrt fuel injector o-rings (HELP)
hey guys i finally finished up getting the lsxrt intake on but i have a problem....
where the fuel injectors go into the intake it seems i need thicker o-rings.
the blue ones i have now are snug but not real tight, after running my truck for a few mins 2 of them where leaking abit.
so i need help finding some that are abit thicker.
here is what i have now.
0.30 ID
0.59 OD
so i need the o-rings with the same ID but the OD needs to be atleast 0.62
if you guys know where i could find some that would be awesome.
Thanks.
Old Jan 23, 2011 | 06:51 PM
saltwatercowboy6355's Avatar
What injectors are you running.
If there stock type injectors did you swap the lower o rings out with the ones in the kit?
Also I am putting my lsxrt together now and feel my injectors dont go in far enough. They seem way to far up and not close enough to spray properly. Im running Delphi 44s
black04's Avatar
I would try contacting racetronix. They are in Canada so shipping will be quick.
Old Jan 23, 2011 | 06:57 PM
the ones that came with the kit are way to loose on the injectors.
im using Fast 60lb injectors.
Old Jan 23, 2011 | 07:16 PM
Atomic's Avatar
I have a gauge for that
Are you talking about the uppers or lowers? The LS1 and LS2 style injector uppers are the exact same, but the LS2 lowers are slightly thicker.
Old Jan 23, 2011 | 07:23 PM
chevyboy.520's Avatar
I'm running injectors off a 2010 silverado 5.3flex. I tried using the o ring fast supplied but they were too big, they would fit at all, so I re used the o ring from the stock 2010 5.3 flex. I'd if that helps, hopefully it helps.
the lowers where the injectors go into the intake.
Old Jan 23, 2011 | 07:29 PM
Atomic's Avatar
Sounds like you need LS2 lowers. fuelinjectionconnection.com can help you out.
Old Jan 23, 2011 | 07:52 PM
what is the ID and OD on the ls2 o rings?
im sure their is a o ring out their from another engine i can use, but who knows what?
Old Jan 24, 2011 | 01:13 AM
i think i found some off a evo i can use, they are .062 OD.
going to find out tomorrow what the ID is.....
