LS7 Rocker Arms
Old Jan 14, 2006 | 12:31 PM
49er's Avatar
Default LS7 Rocker Arms
Has anyone used the LS7 1.8 (#12579617) exhaust rocker arm as a replacement for the 1.7 intake and exhaust rocker arms on their 5.3L engine? If so, how do they perform?
Thanks
Old Jan 14, 2006 | 07:32 PM
tdrumm's Avatar
I have one in a little baggie here that I plan to test fit soon. They probably won't work with my new heads, but I want to at lest see if it bolts up. I think it will. It look identical to a stock rocker.
Old Jan 14, 2006 | 07:37 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Let me know Tdrumm I got a feeling the 237/242 wont be enough for me and that would be alot easier than doing a cam swap. Thats the correct PN right? So its a 1.8 for just the exhaust not intake?
Old Jan 14, 2006 | 07:51 PM
Good luck with doing 1.8s on that cam.
Old Jan 14, 2006 | 09:50 PM
tdrumm's Avatar
That's the p/n for a LS7 exhuast rocker. LS7 intake rockers are offset. You could use 16 LS7 exhuast rockers for both the intake and exhaust of a Gen III engine.
Old Jan 14, 2006 | 10:05 PM
mattrem's Avatar
Does it look like the ones SLP used to sell?
Old Jan 14, 2006 | 10:45 PM
tdrumm's Avatar
It looks exactly like a stock rocker
Old Jan 14, 2006 | 11:07 PM
budhayes3's Avatar
PT's Slowest Truck
I can't wait to see if it fits....a set of those rockers on a Comp 216/220 seems like it would be a nice budget combo for someone (I've seen that Comp grind in various classifieds fairly cheap from time to time...great cam grind, just needs more lift IMO)
Old Jan 15, 2006 | 07:07 AM
mattrem's Avatar
This rocker will be a good choice for using a 1.8 rocker, its like plug and play.
Old Jan 15, 2006 | 08:21 AM
49er's Avatar
I've talked to a friend last night who is "all wise" about GM part interchanges and he says the LS7 exhaust arms will work. You need to take the normal percautions regarding cam lift at the lobe and coil bind. I'm going to order a set on Monday. Will post my results upon completion. Currently using a VHP 044 cam, manley rods and Z06 springs.
