LS6 spring pressure
Old Jun 12, 2008 | 04:30 PM
MPFD's Avatar
11 Second Truck Club
If i read your post correctly your were planning on using them till comp told you they were no good.
https://www.performancetrucks.net/fo...d.php?t=419377
If you ask me comp is gonna try to sell you anything they can talk you into buying.
Old Jun 12, 2008 | 04:31 PM
MPFD's Avatar
Go with 918's they are probably a better spring for the cam your gonna run. I'm just saying that LS6 springs are fine in some applications.
Old Jun 12, 2008 | 04:55 PM
20002wdchevy's Avatar
14 Second Truck Club
Ithink thats the direction I'm headed, I was really looking forward to using the ls6 springs though since they were only $50. Thanks for the input though
Old Jun 12, 2008 | 05:15 PM
Also, this will probly sound like a silly question but do shelf cams from comp cams have the standard GM base circle? meaning that I could use 7.400 pushrods?
Old Jun 12, 2008 | 06:11 PM
MPFD's Avatar
Yes they do
Old Jun 12, 2008 | 09:47 PM
KDT's Avatar
KDT
Go with the "new" 918's. Listen to guys at Comp, they know what they are talking about! They helped me ton's! My 500 hp 04 GTO proves that! They did a custom grind for me and set up the valvetrain! I trust them 100%!!!
Old Jun 12, 2008 | 11:50 PM
00ChevyScott's Avatar
Wearin' da big hat
Shaner does not work with Comp, and I'm not going with Comp springs.
wtf are u smoking man
Old Jun 13, 2008 | 03:59 AM
viciousknid's Avatar
Where's the Beef?
I think the question is what are YOU smoking. See quote below
Originally Posted by 20002wdchevy
the comp cams tech I talked to today said that I needed a spring with 130#s on the seat and 300#s opening.
Regardless of what they've been pushed to, they are only rated to .550 lift and your running 558/563. that alone should be reason enough for you to have never considered using them.
Old Jun 13, 2008 | 04:17 AM
stock48's Avatar
9 Second Truck Club
Remember LS6 valves are lighter requiring less spring. You shouls have at least 130/300 with a cam like that.
Old Jun 13, 2008 | 07:25 AM
Wearin' da big hat
Why did he quote my topic then? If he wasn't talking to me, then I'm sorry for the mix up. But the link he posted is a link to my topic saying my ls6 springs weren't gonna work.
