LS6 pcv swap question
Old Feb 1, 2007 | 09:14 AM
thunder550's Avatar
High on diesel fumes
Default LS6 pcv swap question
I installed my LS6 valley cover last night. The truck PCV check valve is different than the one pictured in the ls1howto.com swap instructions. Does the large end of the truck PCV valve still go towards the valley cover? In the instructions it looks like they reversed the check valve....the pictures show the part that used to go into the valve cover now going into the intake manifold. Is that on purpose?
Old Feb 1, 2007 | 09:54 AM
LARRY01Z28's Avatar
i cant remember how i did mine last time.
Old Feb 1, 2007 | 10:28 AM
thunder550's Avatar
Sweet thanks!!
Old Feb 1, 2007 | 05:45 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Connect the hose coming out of the intake to the valley cover and block off the port on your d-side valve cover or put a breather on it, whatever tickles your fancy.
Old Feb 1, 2007 | 05:46 PM
scatillac's Avatar
Default Ls6 Pcv
Chris,
I believe that the large end would go in the direction of the dirty air (towards the valley cover) and the small end should go to a vacuum fitting on your throttle body or manifold.
The valve covers should both be for clean air (inlets) now, and should vent to the air cleaner side of the throttle body or an external filter (mini-K&N) of some sort.
This is the way it looks on my CTS-V (LS6), but I didn't pull the line to verify the check valve direction.
Hope this helps. (but let me know if it's wrong)
Carl
Old Jul 15, 2007 | 11:49 PM
tb8100's Avatar
hey do you happen to know the part # for that valley cover?
mhorn0817
Jul 8, 2017 01:54 AM
byrne_06
Apr 29, 2017 02:19 PM
The_W
Oct 28, 2015 09:00 PM
Aboss
Jul 9, 2015 10:28 AM
Mzay
Jul 6, 2015 11:03 PM
