Is the LS6 intake manifold a good upgrade?
Old Aug 2, 2006 | 12:04 AM
RabidStreetRacer's Avatar
Default Is the LS6 intake manifold a good upgrade?
I was curious as to if the LS6 intake manifold is a direct bolt on to a 5.3 and is it worth it, i know the truck intakes are made for more low end torque so i've heard on this site. But how's the LS6 intake manifold?
Old Aug 2, 2006 | 12:35 AM
it is a bolt on and it will fit but you will need to modofy a few things like an alternator bracket i think you can get it from speartech, and youll need to bend your water neck a little too. its worth it on endines that are frequently revving mid upper 6k. if you ever plan to shift at 6400 or more-ish then it owuld be worh while. if not then its really not worth the money or the effort.
Old Aug 2, 2006 | 02:34 AM
Quik's Avatar
5 year bitches!
or use all Fbody accesories like i did but unless you rev not worth it IMHO. i used it but i also rev higher and make more topend power
Old Aug 2, 2006 | 08:21 AM
Thanks guys, yeah i don't plan to rev extremly high, i am getting a cam and some bolt on's and just figured it flowed a bit better. But i will put the money to something else.
Old Aug 2, 2006 | 09:21 AM
good plan, what cam are you planning on doing? Quik, could you name all the f-body accessories you bought and used for the intake swap? its something im lookin to do but i need to find the return style 97 LS1 fuel rails somewhere unless someone knows how to modify the fuel system to be returnless.
Old Aug 2, 2006 | 09:31 AM
04BlackSilverado's Avatar
Returnless sucks!! Stay with what you got.
Old Aug 2, 2006 | 09:43 AM
Quik's Avatar
5 year bitches!
fbody water pump, with tension pulley
fbody crank pulley
fbody ALT bracket
you cna use the truck ALT but i usedthe car one also
fbody powersteering. you will need the one hose from pump to rack to work with your stock setup
and the belt since truck has slightly larger pulleys and a longer belt
ebay for a 97-98 vette fuel rail is what i used or buy new
Old Aug 2, 2006 | 10:05 AM
What I have: 5.3, 4L60-E, 3.42's in the rear, all stock and a K&N Filter
MY Plan:
comp cam 216-220 525/532 114 lsa (Might have in a week)
Z06 Springs and retainers (Might have in a week or 2)
Exhaust cutout (already ordered)
LS1 Electric fans (might have in a week)
PCM tune by PCMforless.com
3000-3200 stall
100 shot (already have but don't want to use without all these mods)
3.73's later on
LT Pacesetter headers
Electric cutout. I am probably going to keep my stock muffler becaus ei kinda like it quite especially on long trips being that i drive about 700 miles a week!
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
fat tony157
Jul 16, 2015 12:35 PM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
