drive belt sizes
Old Aug 1, 2006 | 11:50 AM
ltn's Avatar
ltn
Default drive belt sizes
Why is it that some people who switch over from the 105 alt to the 145 alt have to switch to a longer belt. then on the other hand there are some people who do not have to get new belts. Is there a reason or are the people who just dont switch just strecth their stock belts more?
Old Aug 1, 2006 | 08:08 PM
The belt for 145 is a longer belt when you look up part #.Reason being that to much belt tension will cause your accessorie bearings to wear out faster.
Old Aug 1, 2006 | 10:40 PM
SnakeOiler's Avatar
it's just the different tolerances between engines. The belts have a -5mm+5mm tolerance and the next belt size up is actually only 10mm longer.
From what I have heard, the centerline of the 145 alt sits a wee bit higher than the 105 amp.
Old Aug 2, 2006 | 02:32 AM
Quik's Avatar
5 year bitches!
cheaper way to upgrade your charge system is to upgrade your ALTs wire. i currently run a 102amp alt with a stereo, fans, bottle heater and other stuff and dont have any issues with charging with the smaller ALT since i used a larger ALT wire
Old Aug 2, 2006 | 10:35 AM
ltn's Avatar
ltn
how much did it cost to upgrade the wire?
Corvette454l88
Sep 1, 2016 01:24 AM
Stainless Works
13
Nov 5, 2015 03:31 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
