LS6 cam in an LQ9
Old Dec 7, 2006 | 09:49 AM
treyZ28's Avatar
Default LS6 cam in an LQ9
Any real benifit over the stock cam? I looked for specs but couldn't find any
Old Dec 7, 2006 | 10:25 AM
Tootall's Avatar
Did you see that dyno chart on EFI live forum? It was for a 4.8, but it showed the gains.
Old Dec 7, 2006 | 10:53 AM
BLACK04VHO's Avatar
I just say if your going to do it, you wont be happy and wish you went bigger. If your paying someone to do it, go with a bigger cam also. No reason to do it twice. If you trying to stay on the smaller side of cam go with a old man cam or something that is under 220 in duration. this should give you a nice bump and really be torquey.
Old Dec 7, 2006 | 10:55 AM
FarmerBeau's Avatar
Sexy Party Mod
Im sure it'll improve over stock and pull really hard up top but if i had an LQ9 that would be the last aftermarket cam i would put in it.
Old Dec 7, 2006 | 11:05 AM
treyZ28's Avatar
Z06 cams are cheap as are the springs; thats the only reason. I'm just wondering what kind of gains Id get.
also, I have really tall gears with 33's and 3.73s so I'm crusing 70mph at 1850rpm
I want to avoid downshifting and unlocking the converter.
Really, in a perfect world Id have the stock powerband "lifted up"
As long as I have MORE torque above 1500rpm, even if the powerband shifts up, Im ok. I'm not willing to sacrifice anything below 15-1600 though.
Old Dec 7, 2006 | 11:58 AM
kbracing96's Avatar
The Z06 cam is a great little boost over the stock cam, that's for sure. Especially from 3200 on up. It won't fall off above 5000 like a stock cam either. The only reason I swapped it out (to a Vinci Ultra Toquer), is my 4.8 didn't have much low end to begin with, all though I really didn't loose any with it, I didn't gain any either. With a LQ9, you shouldn't have that problem. If you need one, I still have mine, PM me. If I don't sell it soon, I'm going to keep it and put in this 6l I got sitting a crate and put that in some little light weight car and have some fun
Old Dec 7, 2006 | 12:46 PM
treyZ28's Avatar
are we looking at small 10hp/tq gains or something worth doing here?
any estimate on 1800rpm ish torque?
Old Dec 7, 2006 | 01:04 PM
kbracing96's Avatar
I went from a 14.3 to a 13.8 with the cam and meth. It was sgood for probale around 30-40 on my setup, but Im FI.
ARC
57
Feb 21, 2022 10:54 AM
The_W
Oct 28, 2015 09:00 PM
RONIN LSX
Aug 11, 2015 12:03 AM
Denali08
Aug 9, 2015 04:34 PM
Aboss
Jul 9, 2015 10:28 AM
