ls6 cam in 5.3 + 40hp
Old Mar 9, 2011 | 02:08 PM
spiro27's Avatar
Default ls6 cam in 5.3 + 40hp
ive been read a book on how to ls1 and it says by putting a ls6 cam in a 5.3 with springs brings it up 40hp. has anyone done this. did it make a difference. is the story true. any other rec mod to do with it. thanks for help in advance.
Old Mar 9, 2011 | 02:38 PM
Robert91RS's Avatar
The ls6 cam will produce more power but for the money you can usually get a better cam. With a cam that small the only other things you should look for are hardend push rods, valve springs rated for the higher lift and faster ramp rates and a new timing chain would be a sound invetment. If you do some searching you will find alot of previous posts on the matter.
Old Mar 9, 2011 | 05:45 PM
.James.'s Avatar
i had a 4.8 with a 6l cam, then bought a 5.3, tore it down and put ls6 cam an springs in 18k miles ago, the power is there for sure, dont know if it is cuz i stepped up to 5.3 or not, but im going to a bigger cam in my 5.3 soon
Old Mar 9, 2011 | 10:33 PM
06Sierra2's Avatar
to the tr224 in your sig?
Old Mar 9, 2011 | 10:50 PM
bmd_CL's Avatar
40 horsepower? That seems like a lot for such a small cam... Hopefully tho, seeing that thats the cam im probably gonna get
Old Mar 9, 2011 | 11:04 PM
00ChevyScott's Avatar
Wearin' da big hat
I highly doubt you'd see a 40 rwhp gain. Maybe at the crank, but not way you'll see that at the wheels with an ls6 cam, unless you're boosted.
Old Mar 9, 2011 | 11:11 PM
.James.'s Avatar
yes sir, along with some others things ill have to change in sig.
Old Mar 10, 2011 | 07:10 AM
Sc00by's Avatar
I have always heard 20-25 hp to the wheels with an ls6 cam on a 5.3l. So that could be around 35-40 at the crank. The LS6 cam does make a pretty solid boost cam. There are a few people running it and putting down some solid numbers.
Old Mar 10, 2011 | 08:07 AM
chevydad's Avatar
how would this work in a 6.0 2500hd for towing? if i found one cheap is it worth it to put in?
Old Mar 10, 2011 | 08:38 AM
Wearin' da big hat
I wouldn't bother with it honestly. Do you have any other mods to the truck?
