Ls6 cam
Old Apr 14, 2010 | 04:54 PM
williebones's Avatar
Im also looking into a good daily driver setup, i drive 50 miles round trip everyday. do you need to get a different TC if you run the LS6 cam or will the stock one be fine?
Old Apr 14, 2010 | 08:19 PM
Originally Posted by 03CHEVYBOY
i would prefer going with a gm ls6 only becuase of factory reliability, which brings me to my next qurstion, how reliable are the comp cams and will it drain gas mpg ?
Both places sell new GM LS6 cams,
Old Apr 15, 2010 | 12:19 AM
03CHEVYBOY's Avatar
Sweet. So when im ready to do the swap i need the cam(obviously), new springs, and anything else? Rocker arms? While im swapping the cam im going to do the pulleys and belts as well.
Old Apr 20, 2010 | 06:13 PM
03CHEVYBOY's Avatar
Just recived the cam! I have it setting next to my long tubes and orypipe, im waiting for my pulley kit, rockerarm/spring/pushrod/bolt package, spark plug wires, fuel pump and gauges(7krpm, 140mph!!)!!
Old Apr 20, 2010 | 07:11 PM
03CHEVYBOY's Avatar
cam specs comp xr 265. .522/.529 lift 212/218 lsa 114
Old Apr 20, 2010 | 09:05 PM
ssinister04's Avatar
wow nice cam ....i jus scored the gm ls6 cam under 5kmiles along with its factory rods.......new yellow gm springs shipped for 150! im putting it in my full bolton 6.0l since im swaping it into my 4.3l silverado.
Old Apr 20, 2010 | 10:48 PM
fastnblu's Avatar
Originally Posted by Ferocity02
Keep a close eye on the for sale section on LS1Tech. The Z06 guys are always swapping to bigger cams. LS6 cams usually go for around $150 over there.
Nice tip.
i would prefer going with a gm ls6 only because of factory reliability, which brings me to my next question, how reliable are the comp cams and will it drain gas mpg?
gblauf's said his XR265 is a great little cam: .522/.529" lift 212/218 on a 114 LSA, yet idles close to stock & can be run w/. no tuning & stock springs. I hope it's a winner for mileage.
I'm curious myself.
03chevyroyce, the '01 LS6 cam is 207/217 .525/.525 116LSA? Do ya need longer pushrods? Didn't that or is it the '02 Z06 that has a smaller base circle? I was under impression longer pushrods are needed on whichever yr Z06 has that small base circle.
ssinister04 where didja get a LS6 cam under 5k miles, LS6 factory rods, & new yellow gm springs shipped for 150? That's a deal.
Old Apr 21, 2010 | 03:14 PM
i posted up a wanted ad and someone replied!!! i was shocked he just didnt want it anymore he took it out of his vette for another project on his truck but the vett got somen els and this was just sitten i threw a number out and he bit....hopefully its here by friday!
im just not sure do i ned to use the rods also?
Old Apr 22, 2010 | 01:53 AM
03CHEVYBOY's Avatar
YES YOU WILL NEED THE RODS, IN YOUR THREAD YOU SAID "....i jus scored the gm ls6 cam under 5kmiles along with its factory rods......" ASSUMING THE FACTORY RODS ARE FROM A FACTORY LS6 THEY SHOULD HOLD UP IN YOUR 6.0
ARC
57
Feb 21, 2022 10:54 AM
byrne_06
Apr 29, 2017 02:19 PM
darnie
Aug 10, 2015 10:25 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
Aboss
Jul 9, 2015 10:28 AM
