Ls3 can and heads on 4.8
Old May 21, 2012 | 04:09 PM
  #31
2011 4.8 killer's Avatar
https://www.texas-speed.com/Shopping...oductID%3d2941
Ok so here's what I'm looking at. This setup has the 5.3 heads that blackGMC was telling me about with a 220/220 .581/581 114lsa cam a 3000 stall and 4:10 gears. I figure if I'm going to do it then go for it screw 3:73s or 3:90s
Old May 21, 2012 | 04:19 PM
  #32
iamkeniff's Avatar
Do you want any chop? If so go 112lsa. Also put some LTs, a 4" cai an that'd be a strong 4.8
Old May 21, 2012 | 04:37 PM
  #33
Yea I'd like to hear a little bit of choppiness to it and lts are a sure thing as well as the cai
Old May 21, 2012 | 04:40 PM
  #34
$ierraLY5's Avatar
Yeah, go for the 4.10s and a 3000 rpm or higher stall. Trust me, you will like the 4.10s, I think I'm turning like maybe 2400 rpm at 75 mph with my 4.10s. Also you can pick up a Circle D 3200 rpm stall for pretty cheap and they are very good. Then later on if you decide to boost it you will need a stronger converter anyway and you can go for one with a lower stall speed.
Also, is your truck reg cab, ext cab, or crew cab? what size wheels and tires? If it's a crew cab you need the 4.10s, these trucks are heavy.
Old May 21, 2012 | 04:43 PM
  #35
It's a crew cab right now I have the stock 17s on it with a 4/6 drop
Old May 21, 2012 | 04:53 PM
  #36
$ierraLY5's Avatar
yeah, you'll like the 4.10s, I think the 4.8L still has the 4 speed right? yeah, you want the 4.10s.
Old May 21, 2012 | 04:56 PM
  #37
iamkeniff's Avatar
4.8 only comes with the 4spd which is stupid on GM's part. It'd give the 4.8 some ***** behind it with that short 1st gear
Old May 21, 2012 | 05:04 PM
  #38
rjwz28's Avatar
Man Motor club
It should have the 6-speed as standard AND the option for 4.10s. All GM's trucks should by now.
Old May 21, 2012 | 05:08 PM
  #39
Yes I agree it should have a 6 speed but unfortunately I have the good ole 4 boy
Old May 21, 2012 | 05:13 PM
  #40
rjwz28's Avatar
Man Motor club
Yeah the 4L60E will be here until the next gen debuts. Oh well.
