ls1 swap
Old Jul 31, 2008 | 07:31 AM
lo&sloSierra's Avatar
Default ls1 swap
im swapping my junky 4.8 for a ls1 in my 03 sierra and my truck has a fly by wire throttle body, and i want to swap my intake and everything the way it is, can i run the fbw throttle body?
Old Jul 31, 2008 | 10:33 AM
kbracing96's Avatar
Yes, your intake will bolt right on to a LS1
Old Jul 31, 2008 | 06:30 PM
and it will be fine to run the fly by wire throttle body?
Old Jul 31, 2008 | 07:05 PM
viciousknid's Avatar
Where's the Beef?
Your wanting to run DBW on a truck that is already DBW. Think about it.
Old Jul 31, 2008 | 07:11 PM
silveradokidd_4518's Avatar
yes everything will swap over directly with no problems...
Old Aug 2, 2008 | 01:54 AM
sorry i didnt mean to offend you with that question, i have yet to see a ls1 with a dbw throttle body, i didnt know if i needed to swap to a cable throttle body off of another intake
Old Aug 6, 2008 | 10:17 PM
01WS6er's Avatar
your factory ecm will not know the diff when you go to the ls1. just use you intake
i think the corvettes used the dbw when they were ls1's, the later ones anyway
Old Aug 7, 2008 | 09:38 AM
it wont know the difference, but will there be less power gains if i dont have it reflashed?
Old Aug 7, 2008 | 10:10 AM
InchUp's Avatar
Your PCM is tuned for a 4.8L so with the 5.7L in there it will still run the engine like a 4.8L. You haven't told the PCM to do anything else so it will continue to think you have a 4.8L. You must have it tuned to recognize the added displacement.
Old Aug 8, 2008 | 12:06 PM
would it be ok to run it thinking its a 4.8 for awhile?
