ls1 question
Old Mar 26, 2011 | 07:03 PM
84_chevrolet's Avatar
Default ls1 question
I found an iron block ls1 to go in my truck it has 706 heads on it, what kind of compression ratio should it have?
Old Mar 26, 2011 | 10:17 PM
dmelvin's Avatar
There's no such thing as an Iron block LS1. It sounds like you've found a 5.3. Can you verify if it's been bored out to LS1 specs by chance (3.91)?
Old Mar 26, 2011 | 10:36 PM
Yes I can verify the motor is a 5.3 bored to an ls1 an has 706 heads installed on it. The motor runs, but I wanna know if I can put it in my 05 gmc sierra and still run pump gas
Old Mar 26, 2011 | 10:48 PM
dmelvin's Avatar
K... that's what I wanted to know.
The 706 heads have a 61.15cc Chamber
The 241 (stock LS1 heads) have a 66.67cc Chamber
So it'd be like running on a set of .035 milled heads roughly. (using .006 = 1cc)
Roughly, you're looking at 11.1 : 1 CR according to LS1tech:
(https://ls1tech.com/forums/advanced-...ume-vs-cr.html)
I would say as long as you're planning on running 91+ oct. with a tune that's spot on, you could get away with it, I would wait for a couple other guys to chime in just to verify though, I don't wanna be the a$$hole responsible if you ruin the motor.
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
