LS1 intake ??'s
Old Oct 3, 2003 | 10:14 PM
Yelo's Avatar
Default LS1 intake ??'s
I was just given a stock '00 LS1 intake manifold, I know they flow less than the stock 6.0 truck manifold but how much less in relation to what the stock heads will flow ??, what I mean is....will I see a decrease in power swapping to the LS1 intake ??, and will that decrease only be in a place that I never use (over 6000rpm)??
it seems to me that the smaller LS1 runners would help with low-end torque production by increasing velocity at low-rpm, also, since I would like to port this manifold as much as possible I should think that I will not see much of a drop in flow compared to a stock truck manifold...is this right ??
I am looking to swap to the LS1 manifold both for asthetic reasons (it looks better) and I also want to gain clearance near the cowl area because I am working on a rather cowl induction setup (whick may turn into a complete bust but I'm gonna try it anyway) but with the stock manifold it will not fit (stock manifold is too tall)
Old Oct 3, 2003 | 11:05 PM
BigTex's Avatar
Default Re: LS1 intake ??'s
Several people have "heard" that the truck intake flows well. I think the truck intake doesn't flow that well. Sure, with stock displacement, stock internals, stock whatever, it is fine. But for perfomance, it can be much improved upon. I'd think a stock LS1 intake would flow better. Have you looked inside the truck intake? All air is run into a tube that forces the air upward, then out and down towards the head. That may make more torque as it creates a slight ramming effect on the airflow. But this design will definitely make outright performance suffer compared to the open plenum of the LS6.
Once you look inside the truck intake, you'll see why a throttle body spacer will not make one lick of difference.
Old Oct 3, 2003 | 11:30 PM
Yelo's Avatar
is there ALOT of difference between the LS1 and the LS6 intake relative to the truck intake??....I wasn't given an LS6 intake (I wish), I was given an LS1 intake
Old Oct 3, 2003 | 11:46 PM
Banned
the LS6 is said to be worth about 20rwhp over an LS1 intake...so i'd figure it's worth a bit over the truck intake also.
Old Oct 3, 2003 | 11:48 PM
Yelo's Avatar
yeah, but is the LS1 intake any better than the truck intake ??, I thought no but BigTex seems to think it is (and I kinda hope he is right)
Old Oct 3, 2003 | 11:52 PM
Banned
it just makes power in different areas of the rpm band
Old Oct 3, 2003 | 11:59 PM
Yelo's Avatar
so...now back to my original question, where in the RPM band will I see a loss??, if it is down low we can end this thread now, if is is above 6000rpm I will be installing a new intake manifold next week
Old Oct 4, 2003 | 12:23 AM
Banned
there's more to it than just installing the intake manifold....MUCH MORE!!! but i doubt you'll lose any power, anywhere in the band....you'll probably just make MORE higher.
Old Oct 4, 2003 | 12:49 AM
Yelo's Avatar
oh, believe me Slow.....I already know all the stuff involved, I have been talking to a few people about it and already have most of the parts necessary. the '98 Vette fuel rail that has the fuel return line was the hardest to find and the f-body injectors were the easiest, I am also going to mod the alternator bracket (thank you Ryan23Silverado) so that I can re-route the serpetine belt under the the LS1 throttle body location and still keep all of the truck accessories.
I was only going to do this mod for asthetic purposes so as long as the power will remain the same I will be happy
99bluefirebird
Sep 17, 2015 08:05 PM
chvy=power
Sep 8, 2015 11:06 AM
USMCvet0311
Sep 4, 2015 09:43 PM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
