ls1 intake on 5.3L
Old Dec 25, 2006 | 02:08 AM
  #21
chewybravo's Avatar
The truck manifolds outflow the LS6 intake.period.
The only reason i would see putting an LS1 intake on a truck is to upgrade injectors etc. It wouldnt ruin it, but you wouldnt see any benefits from a stock motor for switchin to a LS1 intake.
Old Dec 25, 2006 | 06:10 AM
  #22
have you ever seen a flow chart? tell me you would rather spin to 7000 rpm with the truck intake than with the LS6 intake...
Old Dec 25, 2006 | 08:12 AM
  #23
Sport Side's Avatar
You are wrong. PERIOD
Flow Comparison
Lift______.100__.200__.300__.350__.400__.450__.500 __.550__.600__.650
Port only__71.4_149.5_213.7_233.5_251.7_271.2_286.5_303 .1_280.6_286.5
Rect.Plate_70.3_149.4_206.5_226.9_244.3_259.2_272. 2_275.7_274.6_278.8
Truck Int._70.3_143.9_194.4_209.8_220.5_229.2_234.2_237. 7_243.1_248.5
SSR90mm_70.3_145.0_190.0_205.0_215.9_226.3_238.3_2 48.4_253.0_256.2
LS1 Int.___70.2_142.6_189.1_203.2_216.5_226.9_235.3_23 8.1_238.1_237.4
LS6 Int.___70.2_144.4_200.0_215.8_227.6_238.1_244.9_25 0.2_256.0_263.0
VictorJr.___71.4_147.7_205.7_224.7_240.2_254.7_268 .5_264.2_263.0_275.8
Old Dec 25, 2006 | 05:50 PM
  #24
closet red neck's Avatar
Flow Comparison
We all have determined that the LS6 intake will make a huge difference from down low to past red line. Two or three guys on here have done this mod and gained considerably. Do a search and you can find this info. I'm doing this mod as we speak.
James
Old Dec 26, 2006 | 07:34 AM
  #25
Batman WS-6's Avatar
I wouldn't even waste the money on it. The truck intake is very good to about 6000 RPM. If you aren't at least doing a cam I don't think you will see any gain in HP and you will lose a decent amount of low end torque. Peak #'s aren't everything. Take that money you would have spent on the intake and the MISC stuff to put it on (it won't clear the truck waterpump) and spend it on a good dyno tune and/or some better intake and exhaust components. You will be infinitely happier
Old Dec 26, 2006 | 08:04 AM
  #26
TurboGibbs's Avatar
Truck water pump and LS1 intake:
It WILL fit with very minor clearencing of the TB or the water pump.
Old Dec 26, 2006 | 09:13 AM
  #27
Didn't say it couldn't be done, there are a dozen or more ways to do it. Just said it doesn't clear the truck water pump without modiifcations of some kind. Not everyone wants to grind down their parts to make them fit.That is also a DBW throttle body, only one I ever did was cable actuated and it would have required alot of grinding. When we did the swap for a 55 Chevy with an LQ4 W/ LS6 intake we bought a car pump and had spacers made to line up the accessories and a new tensior to clear the car pump. Looks clean as hell. it can definately be done though. I just don't think it is worth the effort for gains Vs cost unless you just like the look of the LS6 intake, I think a tune will net you more.
Old Dec 26, 2006 | 10:27 AM
  #28
i am pretty sure everyone would agree that its not worth it unless you are spinning over 6200
Old Dec 26, 2006 | 05:03 PM
  #29
bluecajun5.3's Avatar
11 Second Truck Club
don't worry i'll show the gaines
Old Dec 26, 2006 | 05:31 PM
  #30
dirt track racer 81's Avatar
what you lookin to run blue..have you gotten nitrous for it yet?
Corvette454l88
Sep 1, 2016 01:24 AM
Denali08
Aug 9, 2015 04:34 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Black-Syde
Jul 6, 2015 02:12 PM
