LS1 Fans from wrecking yard
Old Feb 3, 2005 | 07:56 PM
OCBC's Avatar
Default LS1 Fans from wrecking yard
I am planning to do the LS1 fan swap soon and I have called around to a couple of local yards to see what they had. One had LS1 fans for $250.00 and another yard had em for $100.00.
My question is in regards to what exactly am I looking for. I know I need the case(shroud), fans, and motor w/ wires. Is there anything else I should look out for? How about condition, should I look for something in particular?
I just want to make sure I am buying the complete package.
Also, I will be fabing up a custum mounting braket(s) (close friend has sheet metal shop), so if anyone wants something along those lines I may be able to work something out. I am thinking something in brushed aluminum or anodized, etc.
Thanks
Old Feb 3, 2005 | 08:29 PM
qwank's Avatar
250 is way too much to pay. 100 is avarage. call around some more. i got mine for 35 bucks! no harness though. just fan motors, blades and shroud. i'll be installing them saturday.
Old Feb 3, 2005 | 08:30 PM
dragonman0325's Avatar
I'd be really interested if you fabbed up some mounting brackets. I'm about to do the e-fans myself. I see them on E-bay al the time for 100$. YOu might wanna check there.
Old Feb 3, 2005 | 09:03 PM
OCBC's Avatar
qwank:
when you say no harneess, does that mean you had no wires coming off off the motor? I plan on getting a harness similar to the nelson to run off the PCM. So I suppose that I dont need a harness anyways.
35!!! NICE. Where are you located? Im in SoCal, so i expect to pay a premium.
Thanks
Old Feb 3, 2005 | 09:14 PM
Eye-P's Avatar
You should not pay more than $100 for these fans. They are on Ebay all the time.
CashDudeHomie's Avatar
Post pics of your brackets. I just put some foam between the edges of the fans and the radiator and some appropriatly bent mending brackets from the hardware store.
CD82
Oct 23, 2015 07:32 AM
Mark_k
Oct 1, 2015 11:17 PM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Dawas
Sep 20, 2015 12:00 PM
