LS1 fans
Old Apr 26, 2005 | 12:58 PM
white1's Avatar
Default LS1 fans
Need help I'm a new guy and picking up a set of LS1 fans for my truck. What do I need to get these working right? I plan on getting the Nelson harness so the install looks factory. I saw something about needing to re-program the pcm for the fans. Please help
Old Apr 26, 2005 | 01:40 PM
TigerFan187's Avatar
If you want the pcm to turn the fans on and off automaticlly then you need to get a updated tune. If you want you can just manually turn them on and off via switch. I would suggest getting the pcm update and if you still have your stock tune then your killing two birds with one stone!
Old Apr 26, 2005 | 05:44 PM
white1's Avatar
Thats kind of what I was thinking, I was just hoping there was a cheap way to get them to work right Till I could save the money for a real tune. Its hard when you're married.
Old Apr 26, 2005 | 05:59 PM
redaddiction's Avatar
You can use relay's one with a key on and then one with a temp switch.
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Dawas
Sep 20, 2015 12:00 PM
FormulaZR
Sep 14, 2015 05:23 PM
