ls1 fan schematic
https://ls1tech.com/forums/showthread.php?t=220998
Note: The PCM 17 connector is incorrect in both images. It should be the A/C clutch compressor circuit.
The 3 relay solution looks like a great setup. Which did you end up using on yours?
i recently installed a set of fans on my suburban and i did the same set up as on my truck but this time i did not use the relays. THey work fine and cool the engine properly but my question is what exactly are the relays for?? Thanks for the feedback in advance.
Well, I'm no electrician, so I can't explain it, but I had the same question when I installed my water pump on my car, way back.
I don't really remember the explanation I received. Hopefully, someone here can explain it.
Wrecker 426
Sep 30, 2015 09:39 PM
FormulaZR
Sep 14, 2015 05:23 PM
