ls1 cam in 5.3
Old Apr 20, 2010 | 05:00 PM
Evil Eric's Avatar
Originally Posted by Bgz71
whats a few other mods i could do to mine
the very first thread that says "See this thread for stickies first" has the answer to that question and more friend.
Old Sep 18, 2010 | 08:48 PM
wheeliE-maxx's Avatar
Old thread bump.. I have a stock 2000 ls1 cam from my dad's formula in my garage (1998 - 2000 Fbody 202/210 int/exh @ 0.05" duration 0.496" / 0.496" int/exh lift 116 LSA), which is an 11* intake and 20* exhaust bump in duration over my 5.3 stock, about .04 more lift aswell. My plans are only tuning and longtubes. I intend to keep a smooth idle and good mileage along with full towing capacity. Time spent (or "wasted") on install isn't a big concern. Mod for mod, could I expect 10 horsepower over the stock 5.3 cam? Compression and everything else is a factor, but ls1's have a nicer idle imo than the blub-blub of a truck.
Old Sep 18, 2010 | 10:29 PM
Big Red Rod's Avatar
Check my sig. I did the 98-99 spec. LS1 cam w/ a hair more dur. but at the same time did heads and injtrs, tuned & headers, It runs pretty good for a 5500lb daily driver, and good fuel mileage, A very streetable 13.9's on motor, no stall, the 410 gear made a huge diff.. It depends what you want to spend and how streetable you want it to be.. A good tune for it would make it run better than installing that cam..
Old Sep 18, 2010 | 10:33 PM
00ChevyScott's Avatar
Wearin' da big hat
5500lbs my ***
Old Sep 18, 2010 | 11:00 PM
With the amps & subs, 20in wheels & weighed at the track...5500lbs, Pull that honda out there and I'll Dust your *ss..
Old Sep 18, 2010 | 11:20 PM
Wearin' da big hat
That's funny, because my 2000 Ext cab only weighed in at ~4500.
And you'll need more nitrous
Old Sep 18, 2010 | 11:22 PM
plan was to install and get a wheatley in truck tune or another local. The stock tune is horrid and pisses me off immensely. My setup will be extremely mild, lightish for a full size truck, and the truck only has 50K miles and doesn't appear to have been ragged on (old man truck). I'm thinking 100% tm delete would be safe on this one
Old Sep 18, 2010 | 11:48 PM
A Low Dime's Avatar
13 Second Truck Club
Im your huckleberry.....
Old Sep 19, 2010 | 01:23 AM
hucklelberry for what, I've got a little 91 AWD talon turbo, cams clipped & ported, 28psi w/450 hp that we can play with if you like Mr huckleberry.. You can't hook that up.. I see your in Dallas, we need to hook-up and play, And lets see what that s10 can do w/my talon..
Old Sep 19, 2010 | 05:15 AM
Killtank's Avatar
alright guys thanks. trever1t whats a few other mods i could do to mine
Forget the cam! First get a Tun, exhaust, and a better intake. It is not all the expensive and you will notice the difference! Especially after a tune!
