LS1 or 6.0?
Old Oct 8, 2006 | 09:46 PM
sroach20's Avatar
if your gonna stroke it why not go 6l block? how much are you spending for the engine and trans? you might be paying allot more than you need since you already have a trans that will bolt right up.
Old Oct 9, 2006 | 09:12 AM
TigerFan187's Avatar
I put a LS1 block in my truck a few years back. I used my stock tranny,inbtake,heads,injectors,pcm,and all the accessories. The only thing thaty changed was the block. Its a "plug and play" (hehe) engine swap as a 6.0 would be. Im at the point now though that the truck intake,heads,and injectors gotta go. They are holding me back big time since I put a fairly big cam in. When I had the 212/218 which was on the small side for a LS1 everyhting was fine. Basiclly Im saying depending on your long term plans(and really think about it becuase all of us, ok alot of us say their gonna stop here and dont) the truck heads and intake will be ok.
Now as far as price. It depends on how good of a deal your getting. A brand new LS1 block is more expensive than a brand new 6.0l block. So research that before you buy. I got a pretty good deal on mine. It had like 12k on it with a 228/228 cam in it and I got it for 800 from the shop I was using at the time. Do I have any regrets? Hell no it been great.
Old Oct 9, 2006 | 01:56 PM
benvortec's Avatar
You stated earlier that it was a "complete motor" and I assume that means with all accessories like water pump, alternator, (all belt accessories). If this is true then you can install it straight up and not have to use anything from your truck motor. Then you just need to get a tune to make it run smooth.
Old Oct 9, 2006 | 02:09 PM
UBLUZIN03's Avatar
The ls1 is forsale for....$400 bucks... I need to check with the person and see if he still even has the engine. I want my truck to be a low 12 sec all motor truck... thats why i want to buy the ls1 and build it up while in school then drop it in after im done school...
Old Oct 10, 2006 | 01:37 PM
UBLUZIN03's Avatar
Would there be an advantage to go ls1 over 6.0?
Old Oct 10, 2006 | 01:42 PM
99/5.3w/hips's Avatar
you will have to swap your fuel rails I believe because I think your on a returnless fuel system and LS1's are not unless its out of a 97-98 vette...i may be wrong on this so dont quote me...someone please correct me if im wrong
Old Oct 10, 2006 | 04:31 PM
Nikon02's Avatar
As far as the ls1 being swapped in the place of any of the LSX based truck motors it should be plug and play. Use all of the truck stuff (intake, manafolds, fuel rails, coil packs)
You do not have to change anything. just run the truck setup.
a friend of mine put an stock ls1 into his truck and gets way better milage and it runs pretty well. Stock for stock the ls1 and 6.0 are very close motors. I (meaning my opinion) would be to take the ls1 at the cheaper price and go from there.
Old Oct 10, 2006 | 06:26 PM
UBLUZIN03's Avatar
Yea i hear ya Nikon.. the ls1 is just a damn good price.
So if i wanted to use the ls1 intake i would need to change the fuel rails? and what else?
Old Oct 10, 2006 | 06:33 PM
Nikon02's Avatar
First i would find out if it is an LS1 intake or LS6 intake. The ls1 intake pretty much flows the same as the truck intake. The ls6 is the much better one for OEM. I have seen alot of write ups on this on the internet and in magazines comparing the three OEM intakes.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
