LS1 or 6.0?
I know a guy who can get me a LS1 motor for real real real cheap and its a compleat motor..should i do that swap or 6.0? The LS1 has 60000miles on it but im going to an automotive school and i can rebuild it or have it machined to whatever i want.. What all whould i need besids swaping the intake on the LS1 to make it work in my truck?
I know i need a PCM but dont i need to change the water pupmp and modify the injecter rails is i use the LS1 intake? Also will the LS1 trans bolt into my truck? I know its an automatic so im guessing its a 4l60e or maybe a 65e? Or should i just use my truck trans?
everyone here is guna say 6.0 but i havent seen a 5.7 ls1 truck put down bad numbers yet. if i can ever talk the guy whos motor i bought to take it outa his car ill be be adding a ls1 to my truck
If you can get an LS1 for cheap then go that route, not enough difference between two to justify the cost.
if you have a 4.8 you could use your trans, computer , and everything on an ls1 or 6.0. trans is a 4l60e and yes youd have to rig your wp and stuff to use the ls1 intake. stock computer will work even without a tune, it would go better with a tune.
Well the ls1 comes with a trans is it the same on in my truck? Also i would build it wile im in school so i would put a cam and heads or maybe bore and stroke it...the possibiltys are endless..haha
