Are the LS based motors in the '99+ trucks as reliable as F-bodies/Vettes?
Old Apr 5, 2005 | 09:46 AM
QUIKAG's Avatar
Default Are the LS based motors in the '99+ trucks as reliable as F-bodies/Vettes?
What parts are the same and what parts are different in the engines?
The reason I am asking is that I had an '01 C5 with the LS1 up until last week. I put 41,000 of the most brutal miles possible on that engine with track days, autocrossing, roadracing, drag racing, triple digit highway runs and it kept coming back for more. The engine seemed stronger when I sold it than when it was new. 'Add oil and go' was my motto. I would sit near redline (6000rpm) for upwards of 30 minutes at a time while on various roadcourses in the area. Oil temp. would soar close to and above 300F. It was incredible.
So, I'm wondering if I use Mobil 1 and a good filter in my '04 Silverado, could my 5.3L theoretically handle a similar amount of abuse? Of course, I will not subject it to the torture I did my Vette, but I'm just wondering if I can cruise down the highway at 3,000rpm all day long or floor the truck frequently to redline and not have any significant deterioration in reliability?
Old Apr 5, 2005 | 09:54 AM
GREGGO's Avatar
Theoreticly, sure it can handle it. But your rev limit is 5600 unless you tune it. Tranny will go first. Like I said in the other thread, I towed in the summer here in Texas for two years with my truck, probably 15k towing miles. My traveltrailer was over 6000#'s and I towed in third which kept the RPM's at 3200 most of the time. Never a reliability problem with 50k on this motor (first one died of an overdose of n20). That motor never towed though. It was the second one that towed. Mobil1 and A/C Delco (OEM) filter since day one on the new motor.
Old Apr 5, 2005 | 09:59 AM
01Blackerado's Avatar
Theoretically it should hold better. Its a cast iron block vrs a alluminum!! And most internals are the same. Aside from the cam and pistons
Old Apr 5, 2005 | 10:07 AM
GREGGO's Avatar
Forgot to help on the first question. Truck engines vs 5.7 LS1.
Iron block - Alum block
different heads on all truck engines
different bore
5.3 and 5.7 crank is the same size, but the 5.7 crank has been drilled to make it lighter
Oil porting same as LS1, not LS6
Accesories / sensors
intake
A couple of mounting points for accesories
pulley
Old Apr 5, 2005 | 10:19 AM
CAMMIN03''s Avatar
Banned
Ive been abusing my truck for 75000 miles now.... I floor it at least 10 times a day,pulling to 6000 everytime.... if not more.... i sometimes manually shift from 3 into 2nd.... I run it up to 110 at least twice a week.... soemtimes 115-120...... Havent had a problem yet.... We go to the dragstrip all the time.... Street Race all the time......Works perfect
Old Apr 5, 2005 | 10:36 AM
QUIKAG's Avatar
Thanks, guys. So, all the motors are six-bolt mains and most similar internals with maybe the pistons and heads being different? Sounds like the 4.8/5.3/6.0 family of truck engines is pretty tough too. That is good to hear!
Old Apr 5, 2005 | 10:41 AM
GREGGO's Avatar
You are correct sir!!!!
Old Apr 5, 2005 | 10:57 AM
TigerFan187's Avatar
6 Bolt Mains-
Old Apr 5, 2005 | 02:32 PM
QUIKAG's Avatar
What is the highest recorded mileage that anyone knows about for the LS family of truck engines? I've heard several in the high 100's.
ARC
57
Feb 21, 2022 10:54 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
