Are LQ9's really worth the extra $$$$?
Old Feb 19, 2007 | 07:14 PM
Quik's Avatar
5 year bitches!
Originally Posted by ap2002
that is what I am planning to do to my LQ9...
as far as if its worth it??? I dont know??? read alot on here and see what people have run... I have a LQ9 and running 12.5 in an ext. cab.. all motor...
that was my old combo which now has a trex in it..with that much CR and a 110 LSA it has alot of lope
Old Feb 19, 2007 | 07:16 PM
adam1803's Avatar
I say that it definetly isn't worth it. The compression ratio can easily be overcame with a set of smaller CC heads. Besides that the only difference is the rods, which you'll have to beat on pretty hard on all motor to break them.
Old Feb 19, 2007 | 07:17 PM
Quik's Avatar
5 year bitches!
.5 in CR is well worth it!!!!! when you go big cams you need compression or else youll be a dog down low
Old Feb 19, 2007 | 07:29 PM
Mangled03gmc's Avatar
Baltimore Whore
pre 05's the diff are the lq9's have stronger rods, different pistons, more comp. If it is 05 or later they are the same, went to the ls2 internals. If ya can pick up a lq4 for the rite price get it and put a diff set of heads to bump the comp up.. All the lsx can take one hell uv a beating and live...
John
Old Feb 20, 2007 | 08:02 PM
99Silver6.0's Avatar
For the money most joints want for the LQ9 no it isnt worth it. They pull it out of an Escalade or an SS and the engine automatically becomes a big pile of gold! You can get a .5 bump in the CR with a Q4 using thinner gaskets and a bit of a mill on the heads. Prolly gonna be a good bit cheaper. If your gonna get heads or headwork, just go for a Q4. Then you get back your .5 maybe a bit more depending on what you do.
Old Feb 20, 2007 | 11:17 PM
treyZ28's Avatar
depends. I'm not tearing it apart - so yes. The Lq9 crank is heavier too
Old Feb 20, 2007 | 11:41 PM
Who told you that?
Old Feb 21, 2007 | 08:09 AM
treyZ28's Avatar
Originally Posted by 99Silver6.0
Who told you that?
The internet. It's that site that shows you all the different stuff about the gen 3 engines.
Old Feb 21, 2007 | 08:36 AM
Quik's Avatar
5 year bitches!
just think anything you do to get CR with a Lq4 you can do with a Lq9. but dpending on the price you can get each for would determine what worth or not
Old Feb 21, 2007 | 08:44 AM
Tootall's Avatar
5.3, ls1 (5.7) 6.0 ---all have the same crank, same size, same weight, same part No.
the 4.8 is a different stroke
