Are LQ9's really worth the extra $$$$?
Old Feb 21, 2007 | 09:26 AM
  #21
onebadrubi's Avatar
the 5.7l crank is same dimension just gun drilled for balancing. 5.3l/6.0 are the same.
Old Feb 21, 2007 | 10:00 AM
  #22
thunder550's Avatar
High on diesel fumes
Originally Posted by Quik
.5 in CR is well worth it!!!!! when you go big cams you need compression or else youll be a dog down low
I'll second this comment. Low compression + big cam = teh ghey.
Old Feb 21, 2007 | 10:04 AM
  #23
99Silver6.0's Avatar
Originally Posted by Tootall
5.3, ls1 (5.7) 6.0 ---all have the same crank, same size, same weight, same part No.
the 4.8 is a different stroke
Thank you.
Quik,
I wont argue that price really will be the deciding factor. I got my LQ4 a hell of alot cheaper than I found any LQ9 for.
Thunder,
A huge LS1 cam with shitty valve events in a low CR LQ4 is ghey sure. But a cam with good VE's in a stock compression LQ4 will make a big difference!! You leave alot on the table if you get a 5.7 LS1 oriented cam and slap it in a 6.0 because you are effectively changing the DCR. Gotta keep the valve events in mind is all I was getting at.
Old Feb 21, 2007 | 10:12 AM
  #24
thunder550's Avatar
Originally Posted by 99Silver6.0
Thank you.
Quik,
Thunder,
I agree with you 100%. I learned a valuable DCR lesson with my 408....after I already bought and paid for all of it and had it assembled. Just sharing my .02
Old Feb 21, 2007 | 10:22 AM
  #25
slowprocess's Avatar
I think we've overlooked the question here.......He's asking if its worth the extra money for him. When you look at his goals(low 12s/high 11s on gas in a rcsb), I would easily say that it is not worth the extra money. That is money that can be spent other places, money that would also have to be spent after the LQ9 purchase as well(cam, springs, slicks, converter, etc)
Old Feb 21, 2007 | 11:41 AM
  #26
Thats the reason I didnt go for an LQ9 in the first place. Because I know good and well that 12's-11's is posible with the LQ4. Slow, your truck is a good example.
Old Feb 21, 2007 | 12:35 PM
  #27
2002C5COUPE's Avatar
Thanks! That's what i was wanting to know. I was thinking an LQ4 would suit my needs, and be as fast as i want it to be, but i wanted to ask some people who have been down this road just to make sure
Old Feb 21, 2007 | 02:46 PM
  #28
LQ4 can take you there man. I did the swap in my old truck.
Old Feb 21, 2007 | 02:54 PM
  #29
TurboGibbs's Avatar
Originally Posted by nightrunner
if its a 05-up model lq4/lq9 they have the same rods - LS2 rods to be exact
All LS2's and 2005 and up lq4's have LQ9 rods. LQ9 and it's rods came 2 years before the LS2
Old Feb 21, 2007 | 05:28 PM
  #30
83 Chevy's Avatar
Don't forget that the LQ9 has aluminum heads (with higher CR). The LQ4 has cast iron heads.
Mike
