LQ9 with LS1 how would it work?
Old Dec 7, 2005 | 08:41 PM
Default LQ9 with LS1 heads how would it work?
Just like the tittle says! How would LS1 heads work on an LQ9? Im asking that because i can get the LS1 heads cheap and if i do get the LS1 heads they are already ported and polished?
Old Dec 7, 2005 | 08:49 PM
desTRUCKtive's Avatar
Hell I would go with it you would be raising your compression a bit probley close to 11, but I am just estimating. I would really for it. You have a RC and if you dont tow that much I think it would be great.
Old Dec 7, 2005 | 10:03 PM
SnakeOiler's Avatar
The LQ9 heads are based on the LS6 design - you wouldn't find me trading them for LS1 heads (ported or not). - but that's just me.
I think it would be better just to port and polish the heads on the LQ9.
Old Dec 8, 2005 | 02:59 AM
The reason im saying that how would LS1 heads will work on an LQ9 is because i dont have the 6.0 heads i bought the 6.0 but the heads were missing. Thats why im asking that how would the ls1/ ls6 heads work on my LQ9!
Old Dec 8, 2005 | 05:54 AM
SnakeOiler's Avatar
That sucks.
I would say, they would work just fine.
Old Dec 8, 2005 | 09:48 AM
F8L Z71's Avatar
They worked fine on my 5.3L. I did 345rwhp N/A with a jacked up stall converter. Of course my heads are welded up and milled so it bumped my CR from 10:1 to 10.8:1
Old Dec 8, 2005 | 09:59 AM
budhayes3's Avatar
PT's Slowest Truck
I think that the compression would bump up quite a bit, but with good fuel, the right amount of timing, and keeping the temps down, they should work. If you check around, you can find some clean 317 casting heads for $300 or less though...there's usually a set or two on ebay.
Old Dec 8, 2005 | 01:00 PM
So the LS1 heads should work fine then right? so i can give the money to the guy that has the heads.
ARC
57
Feb 21, 2022 10:54 AM
The_W
Oct 28, 2015 09:00 PM
Denali08
Aug 9, 2015 04:34 PM
blackdc3
Jul 7, 2015 07:52 PM
Black-Syde
Jul 6, 2015 02:12 PM
